Question about Dryers
Dryer does not heat up and now wont start!
Dryer: Roper by Whirlpool-5 cycle electric dryer.
Power supply: 220 volts confirmed at main power terminal in dryer/rear panel removed.
Initially the dryer would start but the element would not heat up on any setting. The heating element was replaced along with the timer. The unit would start but again would not heat up. I was probing with a dvom and may have caused a short circuit. Now the dryer wont start in addition to not heating initially.
  • 248 Answers
Recheck for 220 at plug. May have tripped breaker.
PULL PLUG FIRST!!
Remove rear panel. Check for continuity at white thermal fuse located near bottom center on the blower housing. It should close to 0 resistance. Also check hi-limits on side of heater housing. Also should be close to 0 resistance. If any are open, replace and clear venting. Also remove 4 screws on bottom of filter housing and pull bottom of housing out. Reach in and remove lint.
Posted on Nov 15, 2007
Dryer tumbles but does not put out heat
Make sure the unit is not plugged in when testing these fuses.You should also check the continuity on the heating element if all fuses check out as good.You may also need to check the main power at the terminal block and make sure you have 220 volts to the terminal block.These are all located on the rear of the dryer remove the back panel to get to them.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Mar 19, 2011 | Kenmore 62602 Electric Dryer
No start/No heat condition!
Suggestions
1. diconect power
2.check continuity of door sw
3.if able to access motor terminals check for open windings
and check to motor case for short to terminals
4.check heater terminals for open circuit
When you bypassed the start sw was there any sound at
all from the motor?
Nov 18, 2007 | Dryers
My roper electric dryer was working fine then i put a load in and it wont turn on. Yes it is plugged in. Do you have any idea what it may be?
Yes,I have a good idea.
First,take your volt meter and verify 220 volts are in fact coming to the dryer terminal block.
If it is,unplug the dryer.
Remove the rear panel.
Set your volt meter for ohms.
Unplug the thermal fuse located on the left of the main exhaust vent.
It is 1 and 1/2 inches long by 1/2 inch wide and white in color.
Touch the 2 meter leads to the 2 terminals on the thermal fuse.
No trading is a bad fuse.
Replace it.
If the fuse gets a reading it is OK.
Then,open the top lid from the cabinet and check the door switch for continuity.
If there is no continuity,replace the door switch.
Sep 14, 2010 | Roper Dryers
Whirlpool Ultimate Care clothes dryer heater does not come on
First verify you have 220 volts of power at the terminal block on the rear of the dryer.
If power is OK use your volt meter set for continuity and check the door switch. With the door closed it should get a reading.
Finally,remove the rear panel from the dryer and check the thermal fuse located on the left of the main exhaust duct. It is about 1 and 1/2 inches long by 1/2 inch wide and white in color.
Remove the 2 wires and check for continuity with the meter.
No continuity is a bad fuse.
It is replaceable,not re-settable.
Sep 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Control Panel in my whirlpool duet dryer model #GEW9250PWO will come on & the dryer will not work at all. Unplugged dryer and plugged back up still doesn't come on. The light within the drum is on when...
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
Jul 14, 2010 | Whirlpool GEW9250 Electric Dryer
My GE DPSB620ECWW does not light up the pannel or
Check circuit breaker at the house electric panel, if good, check for voltage (220/240)volts at the receptacle that the dryer power cord plugs into, if good, check for voltage(220/240)volts at the dryer terminal block where the dryer power cord connects to the dryer, if good, check voltages at the dryer power transformer, should be 220/240 volts for motor,and 110/115 volts control power for dryer controls, you should find the failure within these inspections/testing.
Good Luck !
Mar 15, 2010 | GE Profile DPSB620ECWW Electric Dryer
Dryer won't start, is it the start relay switch or something more complicated
First verify 220 volts of power to the terminal where the cord attaches. If voltage is OK,remove the rear panel and locate the thermal fuse on the left of the exhaust vent. It is 1 and 1/2 inches long by 1/2 inch wide and white in color. Turn off the power to the dryer. Remove the wires from the fuse. Check the fuse with a volt/ohm meter set for ohms. No reading is a bad fuse. If you get a reading,check the door switch for continuity.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
No heat and autosense timer does not shut off. Is this just the thermal fuse or is the element bad?
There is a thermal fuse located at the top of the heat canister that could be bad. The heating element could be bad. The 220 volts power to the dryer could be bad.
You need a volt/ohm meter to check these out. Set the meter for volts. Remove the service plate from the rear of the dryer where the cord connects. Check for 220 volts incoming. Check the wires there to make sure one has not burned loose.
Remove the rear panel to access the heat canister. Turn off the power or unplug the cord. Set the meter for ohms/continuity. Remove the wires from the thermal relay on the top of the heat canister. Touch each meter lead to each of the 2 terminals on the relay. If it reads,it is good.
Remove the wires from the heat element. Touch both leads from the meter to each terminal on the heater. If it reads it is good.
If any part does not read,replace it.
Sep 13, 2009 | Roper Dryers
Electric Dryer No-Start/No-Heat
Try check your timer, and see if you have voltage going to motor. Also check to see if you belt is installed. If broken there is a switch to the belt also. Try check you Door Lid Switch.
Nov 18, 2007 | Roper REX4634KQ Electric Dryer
Re: no heat and timer not moving
  If the timer is set for a auto dry cycle,  the timer won't advance if not heating.  You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Roper RES7646KQ Electric Dryer
Dryers Logo
172 people viewed this question
Top Dryers Experts
