Question about Maytag MAH6700AWW Neptune Front-Load Washer
MAH4000 washer how do you remove the bearings for replacement
  • 248 Answers
This job requires replacing outer tub. If you want, I can spell out whats involved. Expect at least a couple hours and a pretty large parts bill. Let me know!!
Posted on Nov 15, 2007
Replacing rear wheel bearing. how to remove?
Remove the rear wheel, then the bearing cap. Then remove the split pin out, the crowed washer and bearing nut & washer. Now remove the outer tapered bearing, and the brake disk ...
Aug 15, 2011 | 1997 Audi A4
On my maytag neptune model # mah4000aww the spin cycle is extremely loud and I recently noticed that midway thru the cylce there must be a leak as a small amount of water is on the floor under the front...
Hello, it sounds like your Neptune's bearings and seal need replaced... See NeptuneBearing for more info on replacing your bearings and renting the special tool kit to save you time.
I see that you have a MAH4000 Neptune. Did you know that your machine shipped with a faulty door latch wax motor that will eventually damage the control board? See NeptuneHelpSong for a video that explains what happens when it fails. You can proactively upgrade your wax motor before it fails and prevent the failure to the control board.
I hope this helps...
Apr 20, 2011 | Maytag Neptune Washer
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
May 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Tool to get tub bearings in and out on mah4000
you can rent the "TONY-TOOL" on the web for $79.00 or you can make one out of a piece of pipe 11/2" in diameter with a pipe joint screwed onto this piece of pipe on one end and it does the same thing
Apr 19, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Mah4000 maytag how to locate remove and clean
if you think your problem is a dirty sump run a good quality appliance cleaner trough it first much easier than stripping down machine give it a go
Nov 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Mah4000 won't go into spin cycle. drain pump is working, but no high speed spin.
Hi, this is MCU damage. This is called the Motor Control Unit. it manages the spin cycle in your unit. it is damaged at this time. replace it asap.
Jun 25, 2009 | Maytag Neptune Washer
Neptune MAH4000 AQW belt will not stay on.
If you installed the belt correctly but it still comes off, that means most likely that the drum pulley is tilted, which indicates another problem - the central bearings are going out. Another symptom for that is a loud noise when the drum is spinning fast. The cure for that would be replacement of the outer tub or just replacement of the bearings with seal.
If there's no noise during high spin - check if the drum pulley or the motor is loose.
Good luck,
First Choice Appliance
Jun 19, 2009 | Maytag Neptune Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Whining during spin cycle
Could be a loose belt, or drum bearings,or ( drum rollers if your model is so equiped) In my mind machine would be worth repair when needed.
hope this is helpful
Jan 17, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag mah4000 washer
My machine (Maytag MAH4000aww) failed to drain because of a bobby-pin that was lodged in the drain pump impeller. Because of the added weight of the wet clothes, and the undrained water; the machine would not spin. The Wax motor worked as the door did lock properly, but the machine would "ramp up" trying to spin, but would stop the process when it sensed that the load was grossly unbalanced. Check the drain pump to see that it is not clogged or that the impeller is not impeded by a foreign object before spending money on imbalance switches! I will now cancel the service man, who surely would have charged me for a new pump, plus the cost of the visit, and now I can stop swearing! My wife is glad she married me!!!!
Rene Marchand (Beaumont Alberta)
Jan 13, 2008 | Washing Machines
Maytag MAH6700AWW Neptune Front-Load Washer Logo
120 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
