Question about Conair Health & Beauty
How do you clean a conair nose hair clipper? It is model NE15388, and it no longer clips--the battery has been replaced and the motor sounds like it is running, but the head does not move.
zeusfaber
  • 247 Answers
SOURCE: Remington HC600 hair clipper stopped clipping
This might be as simple as putting a drop of light oil into the gap between the fixed and moving blades. A.
Posted on Jun 28, 2007
  • 62 Answers
SOURCE: Hair Clippers not clipping
All clipper/trimmer blades must be oiled both before and after use. Hold the unit with the blades pointed toward the floor. Put a dab of oil across the front of the blades and turn the unit on to get the oil distributed through the entire blade. Turn the unit off and wipe the blades with a soft cloth to remove any excess oil.
Posted on Jan 07, 2008
  • 87 Answers
SOURCE: Oster Golden A5 clippers not cutting
The stationary blades are held on by a couple of screws. Loosening these screws will allow some lateral movement of the blades. Adjust the blades till the proper alignment is restored. Just like scissors, there must be gaps between the moving and stationary blades at one point, then the moving blades close the gaps which cut the hair.
Posted on Mar 16, 2008
SOURCE: conair hc318d reassembly
you can buy another blade set for that model. Call 1-800-3-CONAIR
Posted on May 26, 2008
SOURCE: Conair Champion Hair clipper
i have an "hc318d" conair hair clipper. i took the two screws off to oil the inside and now i can't get it put back together properly. can u help?
Posted on Sep 14, 2008
Replacement blades for conair hair clippers hc114wv
I have a Conair HC114WVR and I took the blades off to clean the hair out. It's not that old, but when I put the blades back on they vibrate to a point of grinding. I can't figure out what I need to do to get them back on straight.
Jan 25, 2014 | Health & Beauty
Won't cut anything
we have had this problem many times with our hair clippers
take off the outer blade and make sure it is all clean and there is no hair within the working when rebuilding add a little regular household oil
on the side of the trimmers there is usually a little plastic screw built into the casing this is the motor adjustment turn it until the trimmers become noisy then turn back half a turn so it lowers the noise out put hence the motor speed hopefully this should work
Dec 14, 2011 | Conair HC117 Hair Trimmer
Clippers stopped clipping. I changed to a new blade but it didnt help. I took the clippers apart and put in a new holder for the clippers. I put the clippers back together and although they clip a little...
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
Jul 05, 2011 | Andis AGC2 Hair Trimmer
WHAT DO YOU CLEAN THE CLIPPERS WITH AFTER USE - I USED THEM ON MY SHEPHERD AND THEY WORKED WELL, BUT I DO NEED TO CLEAN THEM. THANK YOU
"Kool Lube" by Oster works to clean and disinfect the clippers. Hair should be removed first, this can be done by cleaning out hair with a toothbrush. Kool Lube is available at beauty supply stores such as Sally Beauty.
Aug 05, 2010 | Conair Health & Beauty
I have conair haircut kit 10 piece and i used it on my brother and it keeps pulling his hair and i turned the power on switch it still pulls his hair whats wrong with the clippers
Sounds like you may need the blade sharpened, it may be dull, otherwise the motor may not be functioning properly. Does he have thick or coarse hair? If so, you may need to go through it lightly in sections otherwise it will for sure pull, I learned that way back in hair school long ago. :) Goodluck!
Apr 02, 2010 | Conair HC90CS Hair Trimmer
I need a manuel for model hc200 conair hair clipper in a download form
http://www.conair.com/instruction_booklets/HC200ACS%20IB%209-29-061.pdf
Jan 25, 2010 | Conair HC200XCS Hair Trimmer
Clippers jam and won't cut when trying to use attachments
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
Aug 04, 2008 | Conair 5200
Health & Beauty Logo
89 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Steve Allison
Steve Allison
gbob59
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
