Question about Standard (CRT) Televisions
TV doesn't have channels 2 - 6
I recently became the owner of a RCA F19424 19" TV. The TV doesn't have channels 2 - 6. The TV goes from FRT to channel 7. I tried to add Channel 2, but all I get is the CBS logo at the bottom center of the screen and snow. Any help?
  • 236 Answers
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Posted on Sep 09, 2007
BMW Rider
  • 232 Answers
SOURCE: TV. dpops channes
Bill, your set has a bad tuner, only fix for that is to R & R the tuner, 2nd option would be to use your vcrs tuner input and then RCA out cables from vct to input on back of tv, If you have never done this re-post and I`ll walk you through it, let me know, BMW Rider
Posted on Dec 05, 2007
  • 1694 Answers
SOURCE: no sound on channel 7
In audio menu, find selection for SAP and change to stereo...
Let me know if more help needed, provide Model #..........T.
Posted on Dec 11, 2007
  • 5 Answers
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
Posted on Feb 05, 2008
  • 92 Answers
SOURCE: TV, RCA MOD # F19424, CTC 203U5, Picture blury
Focus and Screen. The focus control may help, just like focusing a set of binoculars or an old camera. Watch the picture on the TV, using a mirror can help and make an adjustment until the picture is as clear as you can get it. If it still is not clear it may mean that your picture tube is weak.
If you can avoid it, don't touch the Screen control. If you have, let me know and I can advise you on the proper way to adjust it.
Posted on Oct 09, 2008
SOURCE: Unable to get consistent reception on ABC (channel 7 NY)
The antenna may be the problem in your case but I was getting New York 7 digital with a strong signal before the transition on June 12th and now I do not get any signal. I use a rather large VHF /UHF roof antenna mounted in my attic. The compass heading for NBC NY 4.1 is 169 deg and 18 mile from my location according to I get this channel with a strong signal. Comparably ABC NY 7.1 is 170 deg and 18.7 miles from my location and I do not get a signal. Perhaps ABC NY is having some problem with the transition. It does not make sense assuming the information of is correct. BTW if and outdoor or attic mounted antenna is not an option I would recommend the following antenna. I used this for my friends? setup when she was having problems with rabbit ears. It also got some pretty high user reviews and is not expensive. It is for both indoor and outdoor applications. Good Luck!
Posted on Jun 14, 2009
0 characters
1 Points
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Standard (CRT) Televisions
How do u add and delete channels on a rca 24F512T
1) Make sure that the current input is TV. Then press Menu on either the TV or the remote.
2) Press Ch+ or Ch- to highligh Setup then press OK.
3) Press Vol+/Vol- to highlight TV or CATV as needed for the channels you wish to add or erase.
4) Then use Ch+/Ch- to highlight Channel and then press Vol+/Vol- to enter the channel number that you want to add.
5) Press Ch+/Ch- repeatedly to highlight Add/Erase then use Vol+/Vol- to select whether to add or erase the channel selected above (step 4).
6) Press Menu repeatedly to exit the OSD (or wait until the OSD closes after a period with no key presses).
Then use the Ch+/Ch- buttons to scroll through the channels in memory to see the change.
The manual for your 24F512T is available here: . See page 13 of the manual for extra information on manual tuning and page 15 to add and remove channels from the channel list.
I hope this helps.
Mar 27, 2011 | RCA 24F512T 24" TV
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
No channel 3, the tv goes from channel 2 to 4, can't use the cable box
Two options...
1. Connect the Cable Box via RCA cables (Yellow/Red/White) or Component cable if you have a HD cable box and select the appropriate input on the TV to view your programs. This will provide the best picture quality as well.
2. Make sure the cable box is on. Using the original TV remote type in the channel 03 and if this tunes to the channel then go to the TV menu and then go to Set up and then select add/erase and select add.
If typing 03 did not tune in channel 3 then using the TV remote select menu then go to set up and then make sure TV / Cable is set to cable then on the cable box press the channel button a couple of times and then select auto program on the tv.
Jan 03, 2010 | Toshiba 27AF44 27" TV
I have an RCA 27in. screen TV. Cannot program, all is fuzzy.
try unplugging and plugging back in 2 minutes later. go to menu and find channel selection. scroll down to where it says channel. then using volume up and down buttons. will add or erase channel. just play with it and you will see what im talking about. go to channel 4 and press volume up. this will save channel 4 in memory. if no work, try turn on video souce and do a auto program in menu. fixed. enjoy!
Nov 09, 2009 | RCA F27252GY 27" TV
Can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
Dec 03, 2008 | RCA Standard (CRT) Televisions
Can't get TV onto the AUX channel
Dec 15, 2007 | Toshiba 27D46 27" TV
RCA 32" TV
The most likely problem is a stuck tact switch, if it goes up in channel number, 5, 6, 7, etc. then the channel up button is stuck, if it counts down it`s obviously the ch. down button. Problem is you have to remove the guts of the set to get at the control boards screws, you can try turning on the set and poke around the offending push button with a tooth-pick, if it stops changing channels leave it alone and use your remote from now on to change channels, if you can`t get it to stop the tact switches or the control board module will have to be swapped out, hope this helps
Nov 27, 2007 | RCA F32695BC 32" TV
Sep 09, 2007 | RCA F25254GY 25" TV
No picture channel 2-3-4-5-6-7
bad tuner or gemstar module
Dec 08, 2006 | RCA F32649 32" TV
Standard (CRT) Televisions Logo
89 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
