Question about Kenmore Washing Machines
F35 Its not washing that keeps coming up and I live in the boon docks and dont have the money to have someone out to fix it. Its also new
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I took the bobbin and bobbin case out to clean and oil. Can't get the bobbin case in correctly as the needle comes down an is jammed to the top of the black bobbin case. Singer 2662 This is my friends...
I am not too clear on your problem, but it sounds like you have to get it unjammed and remove the needle by loosening the screw on the needle holder. . Even if you have to cut it and take a pliers to get all of it out. You can download the manual for free at www.singerco.com and under support, instruction manual, enter 2662 in the box. Get the manual so that you know how to remove the needle and insert a new one. The needle may have slipped down and is causing the problem. Remember always turn the handwheel towards you, never away from you, because it can mess up the timing. Good Luck
Mar 12, 2011 | Sewing Machines
My washihg machine kenmore elite H E 3t will not wash it keeps going to F35. how do I fix thisb bproblem
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Feb 27, 2011 | Kenmore Elite 45986 Front Load Washer
Suds, and F35 keeps coming up when trying to wash!
I would put bleach in the detergent slot, run through each cycle. Then run the cycle again with just water. These are really touch when using detergent. Just a little bid of suds sets these things off.
Jul 26, 2010 | Kenmore 44102 Front Load Washer
First SUDS come on and then F35 code
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch. and if this still dont clear your code you will need a new control board.
Jun 11, 2010 | Whirlpool Washing Machines
I have a Kenmore elite washer he3t model 110.4674 and the error code F35 keeps coming up. We did clear out the bottom drain pump, which had a lot of debris including toys, socks...etc. How can I clear the...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^##
Jun 10, 2010 | Kenmore Elite HE5t Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
I keep getting the F35 and the SUD screen also. I unplugged, cleaned it out and still it keeps coming on. Any suggestions on how to fix the problem. The washer is only 1 year old.
Hello there:
Here is a list of things that could be wrong so be sure to go thru each of these and make sure these are checked ok
F35 found in this link
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
F35 ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
you can also copy and past the above website in the browser and go right to the manufactures website ok
best regards michael
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER WILL NOT RUN. COMES UP WITH F35 ERROR AND
analog pressure sensor failure 1 check if the pressure hose is fixed correctly 2 check the air trap is not blocked 3 check if the hose is not blocked good luck
shaun
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keeps flashing F35, when unplugged and plugged back in flashes SUD, there is no soap in the machine. When trying to raise / spin or drain or any other cycle keep getting F35 flashing. This is a Kenmore...
F35 Is an electrical fault in the Control Board.
Try setting the machine on off.
Then remove the plug from the wall for 5minutes. this will usually reset the system and get you going if it is only a glitch in the electrical system.
If this fails to remedy the problem then you have what appears to be a failed control board.
The only way to be sure is to have it diagnosed by a hands on tech.
Or risk your money by swapping it out your self.
The problem is that usually when my customers try this, they end up spending part money and then a service call on top of their failed attempt.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Classic K45SS STOPPED RUNNING
I have the same problem now what did you do to fix it?
Jul 26, 2008 | KitchenAid K45SS Classic Stand Mixer
Washing Machines Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
