Question about Sony Televison & Video
Too dark sony model kv21gmr1
Ihave sony model kv21gmr1 whe i power on picture and sound ok but after a minute the picture goes dark and dark until you cannot see anything but the sound is ok and the osd display is ok i check the supply for abl section supply is good and screen g2 is also good plsssssss can u help me with my problem. thanks a lot
    Problem Solver:
  • 15 Answers
Warning: The following procedures should be done by an expert.
1.First step is to check the physical condition of the set.Before starting troubleshooting try to resolder the board and find any cold or loss solder.Then after plug the set and see if the filament of the tube glows.If not the trouble is in heater circuit.
2.After seeing the filament if it glows, check the CRT socket and open it.If you can see a sign of terminal decay such as greenish unwanted element on terminal surface,replace the CRT socket.
3.If replacement does remedy the problem check RGB drivers and resolder or replace jungle IC.
4.Try also to adjust the screen adjustment found in the flyback transformer.
5.Another possible cause is the vertical IC.Adjust the screen to full and see if their is a white horizontal line on the screen.If so the problem isin vertical circuit.
Posted on Jul 13, 2009
Why is my sxrd60 picture slow to light up (with sound) but eventually comes on dark?
Hello, it sounds like the lamp has gone bad, use only a genuine sony lamp in that set as a generic lamp may damage the ballast in it. The generation of Sony's were bad about that. the lamp # is. XL5200 tks
Aug 08, 2014 | Sony Grand Wega Kds-60a2000 60-inch Sxrd...
Screen goes dark after 5 minutes with sound
Could be the ballast boards for the white light.
Jan 04, 2014 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
55 inch Sony Wega rear projection tv...only stays powered on for a few minutes then goes blank, green light steadily burns and the picture is dark. Is it overheating? What do I need to do to fix this?
If its the model indicated here or one similar(kdf-55xs955) you may be seeing a lamp that is about to fail.
A lot of these just before lamp failure will get very dark and if bad enough the set will even shut off.
Mar 17, 2012 | Sony Grand WEGA KDF-55XS955 55" Rear...
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Element 26 model ELCHS 261. The tv powers up ok but
has problem on the board.the solder is loose or loose solder
Jul 18, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Screen goes dark, sound goes quiet...
I have a sony KDF-E60A20 projection tv. The picture would go out for about 30 seconds and come back on. It would continue to cycle this way. The green power light would stay on and not flash. The sound would go off when the picture went out and come back on when the picture came back on. I tried taking the bottom cover off the back exposing the fan and blowed it out with a vacuum cleaner, also taking out the bulb and blowing it out. That didn't help. So I ordered a new bulb from Advancedlamps.com and that's what it was. I have now had it on and off for two days and no problems. Cost of lamp was $107.00 including shipping. Good Luck!
May 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Televison & Video Logo
181 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
