Question about Nikon COOLPIX L4 Digital Camera
Monitor is lit but screen is blank
My daughter down loaded pictures to the computer. Now screen is lit only. Some time, writing and pictures have came up.
If you cannot find a solution to your problem you may want to email He has good advice and good used parts at a fair price.
Posted on May 22, 2008
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Monitor does power up but no picture??
heck342, Your monitor may have the common "black screen of death" that will occur to ANY AND ALL cold cathode-fluorescent-lamp, back-lit, lcd monitors sometime during their lifetime. You will need to do a lot of reading in my fixya profile and those of "buddymc" , "budmrtn" and then you will understand what you will or will not do with your unit. I'll even bet you haven't been to YOUTUBE to view any DIY repair videos yet! Come back here for more info after you do a little research on the WEB, and can tell us tech's that you know the difference between a "black screen" and a "blank n black screen" monitor. Remember this, your CCFL back-lit lcd unit" design and principle of operation isn't any different than any other brand. Have you done the "flashlight test" that every CCFL back-lit lcd monitor owner should know how to perform and interpret the resulting info when black screen of death occurs? Bye for now. 12fixlouie
Jun 13, 2010 | X2Gen MG19MY 19" LCD Monitor
Screen went blank
cslkkent, Your description of problem fits the common "black" or "blank n black" lcd screen symptom. Because 98 percent of all desktop cold cathode fluorescent lamp back-lit lcd monitors use the same basic lighting technology, it will be in your best interest to view some video clips of CCFL back-lit lcd monitor repair on YOUTUBE just for info on typical causes of black or blank n black screen symptoms and how some owners do repair on the cheap! Yes, your unit may have BAD capacitors on the power supply printed circuit board or one "thermally intermittant" component solder joint which will need to be resoldered. Just do some research first. Read fixya profiles of "buddymc" , "budmrtn" and my own files. Good luck on your quest. 12fixlouie
Jun 09, 2010 | LG Flatron L1919S LCD Monitor
Monitor started flashing then went almost black, very, very faint.
ivanging, Happens a lot!!! You will be able to see screen if you hold flashlight 1" from screen. If unit out of warranty, you or qualified cold cathode fluorescent lamp back-lit lcd monitor technician will need to find root cause of lamps not lighting-up for you to see all the colorful text and graphics. Reading is free on fixya!!! All you need to know has already been written and documented here on fixya. Get yourself into the FIXYA profiles of "louie12fix" (my old file) and "buddymc" , "budmrtn" and follow all links you find there!!! Just remember to return to this posting and write a testimonial about all you have learned about why ccfl back-lit lcd monitors fail. Your unit has good chance for complete recovery from it's "black" but not "blank n black" screen state.
Do some reading and visit YOUTUBE for DIY repair videos to make decision to repair or contract out repair work or just trade for new. Good luck with whatever direction you take. 12fixlouie
May 11, 2010 | Samsung SyncMaster 175V 17" LCD Monitor
Monitor problems--screen is blank but power button lit
Check you video card first, if you can remove it, then have it clean, the contact with an pencil eraser, just make it sure wipe the eraser residue, then put it back again, also check the built in fan on your video card, make it sure it is running
Nov 02, 2009 | HP vs19 (Silver) 19" LCD Monitor
No picture on the screen
hiiiii ther
how r u ??
when u start ur pc is tehr any beeping sound
if the is i guess the video card bosted
u take care and have fun
salammmmmm {bye in arabic}
p.s rate me thanks
Nov 22, 2008 | HP Pavilion DV5234US Notebook Laptop
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Mar 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Turn on the monitor the screen says "out of range" in a small window and turns off
Lower down resoluction and color quality to minimum on your pc, using 'display properties' in Windows. Connect the monitor back to pc with minimal settings. If it works is done.
If it still does not work there is a major problem with the monitor. In this case It should be opened and tested inside following schematics. In this case you may need to take the monitor to a service in your area.
Mar 02, 2008 | Sceptre DCL9a
Unplug the monitor from the computer,
it should display the diagnostic screen on monitor in color.
if not reconnect it and boot computer or attach to a running computer with some stuff on the screen,
get a bright light and shine on the screen at an angle do you see the stuff/desktop.if you do the lamp or power supply is bad.
if the monitor is lit and the lamps work but no diagnostics then the video cpu on the monitor is bad.
post your findings here
Jan 26, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Nikon COOLPIX L4 Digital Camera Logo
32 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
