Question about Sony Playstation 3 (PS3) Console
No display on tv
I have one of the first 20gb playstaion 3, it never worked since new i connected it with av cables and tried hdmi, no display on tv either wav. i also tried different tv's
  • 65 Answers
It won't there is a setting on the PS3 that you have to tell it on the HDMI connection that you want to transfer back to A/V cables. If you don't do that and you have been playing with HDMI and then switch to A/V then it will still try to load using the 1080i settings instead of the 480i thus you will have a blank screen on the TV. Hope this helps.
Thanks,
Ced
Posted on Jul 13, 2009
My ps3 will turn on but there is no signal on the tv and the hdmi cord is hooked up it will say weak or no signal
Try to reset your settings.
Plug in both AV and HDMI cables.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go. Make sure that you are switching your TV from HDMI to AV and vice versa.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options.
Try 1.
If you are able to get the AV cables to work with this method, try setting your HDMI up as you did before.
If you cannot get HDMI to work, then your output has gone out. You must use the AV/Component cables.
If you get no display at all but the system appears to be responding normally (outside of the display) then:
You have what is commonly known as the "Green light of Death."
It is when your system powers on and acts normally but no display. Your GPU (graphics chip) has cracked or become damaged and will need to be sent in to SONY. You can try a 3rd party technician, but this repair has a very very low success rate.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
My dog chewed the power cord on my ps3 while it was on and it triped the breaker in my house ,i got a new power cord but now the ps3 powers up but cant get the hdmi cable to work to tv
It may be possible that he has caused a power outage that disabled your HDMI output. It is a common problem, both HDMI and AV outputs will go out.
Can you get a display with AV cords (if you haven't tried, get them ready)
You may be faced with a problem that will cause you to use AV or Component cables. (recommended if HDMI output is out)
Try 1.
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    Hdmi Port wont work on PS3
    you need to go into your console video settings and setup for hdtv to use hdmi.
    May 21, 2010 | Sony Playstation 3 (PS3) Console
    PS3 HDMI - Sony Bravi KDL-40V2000 Problem
    • Have your ps32_bing.gif in standby mode (red light).
    • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
    • Wait 10-15 seconds. A display will show up, and just answer yes to all!
    try this
    May 08, 2010 | Sony Playstation 3 (PS3) Console
    PS3 hdmi only working on some displays
    I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
    Dec 21, 2009 | Sony Playstation 3 (PS3) Console
    Av connections not giving signal to tv
    you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
    I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
    Please give a fixya rating if you find this solves your problem, Thanks for the question
    Apr 12, 2009 | Sony Playstation 3 (PS3) Console
    The Yamaha RX-V463 AV does not playsound from the blue ray player
    "I am also having difficulties in try to display the yamaha set up menu on the tv."
    According to the manual the display menu for TV will not work with HDMI hook up.
    I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
    Apr 07, 2009 | Yamaha RX-V463 Receiver
    Connecting Gateway HDMI TV to Playstaion 3
    If your PS3 has HDMI capability and the monitor has HDMI capability, it should work as long as the monitor can match to the specs of the PS3.
    I am not sure, but I think the PS3 required the capability of 1080p from the TV set. Make sure that your TV is able to see 1080p.
    For HDTV, the standard A/V cable set is of no use. That is why your monitor probably does not support the standard A/V format.
    Jerry G.
    May 18, 2008 | Gateway FPD2275W LCD Monitor
    PS3 no longer communicating with TV
    All: Try this -
    P
    erform the following steps to reset the Video Output Settings.
    1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
    NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
    As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
    If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
    With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
    If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
    1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
    3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
    4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
    5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
    6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
    7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
    Dec 16, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    69 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    juanmireles1
    Damen Wong
    Damen Wong
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
