Question about Panasonic CT-36HX42 36" TV
My tv picture keeps breaking up slightly every minute or so (as though the power has been cut off for a fraction of a second). it does this on all pictures from sky, dvd and freeview, so i assume this is not a problem with the feed. At times it is worse than others with a discernable crackling sound.
4 Suggested Answers
  • 75 Answers
SOURCE: No power to TV. No sound, no picture.
frist you need to check the fuse it is inside of tv by the power cord looks like this maybe a Panasonic tv did notsee any model number so i will gess as to what is wrong check fuse if blown need to replace with a white glass looking fuse of same value like i said dont know what model number this set is but the thermister could be at falt for the fuse to blow.
Posted on Mar 14, 2009
  • 458 Answers
SOURCE: The TV cuts off frequently. The screen is blank & no sound.
It is probable you have a poor soldered connection on the power supply board, hence the erratic timing of the TV going on & off. If you are competent with a soldering iron look for dry jointed soldering on the board. If not have a service engineer take a look at it for you.
Posted on Jun 24, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Hourglass picture. Panasonic CT-35G30T
This is caused by bad solder connections in what's called the pincushion correction circuit. Some of the transistors get quite hot, and over time the solder connections to the TV circuit board become intermittent. When you tap the set, it causes them to make contact again so the picture is normal, but then it goes funny again. Resoldering the connections would take care of this problem. I would suggest calling a professional in to make the repair, which would cost far less than a replacement TV.
Hope this has been helpful, and thanks for using Fixya!
Posted on Feb 02, 2010
LED tv has no picture and flashes on every few seconds
You have a bad panel (TV SCREEN). The LEDs are not coming on. You will have to replace all LEDS, and this can be very time consuming. The LEDs can be tough to find and buy. Many TV parts store are out of stock. Thanks for asking, Matt of Martins TV.
Jun 10, 2018 | LG Televison & Video
Why does my TV screen keep cutting out
do you lose the audio signal when this happens ?
Sep 05, 2014 | LG Televison & Video
Picture and sound cuts in and out
Lamp inside of your TV set is nearing end of lifespan. Replace it.
Feb 15, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Why does my samsung tv cut off by itself after 1-2 min and flash a red lamp button?
A little explanation first- this model (as do most Samsung DLP sets) will try 3 times to get the lamp lit before the microprocessor will give up and then the 3 lites on the front will blink indicating a LAMP failure. This process takes about 1 to 2 minutes. In order of probabilty, the failures are:
1) A faulty lamp and/or ballast. REPLACE LAMP AND/OR BALLAST
However, a faulty lamp and/or ballast are not the only things that will give this blink code-
2) If the color wheel has a bad bearing and turns too slow or not at all, the microprocessor WILL NOT let the lamp light, and then give a LAMP blink code. A bad color wheel will normally have some sort of abnormal sound- a low growl or high pitched whine is common. REPLACE COLOR WHEEL
3) ALSO, if the microprocessor (on the DMD board) in its color wheel rotation detection or processing fails, once again the lamp is prevented from coming on and you get a LAMP blink code. REPLACE DMD BOARD
IF THE SET EVER COMES ON WITH A PICTURE for even a fraction of a second or though it takes many tries, the lamp and ballast are good. The problem must be either the color wheel or DMD board.
Oct 26, 2009 | Samsung HLR5064W DLP Projection TV
TV picture blanks out, the restores
your tv has a loose board problem, its either in main board or CRT socket.
Apr 10, 2008 | Quasar SP-2719 27" TV
Very wavy picture- gets worse when show has fast-cuts
First thing Do not beleive peeps about a bad card. Modules are not used in TV sets any more unles your talking about a complete board change out for a Zenith TV set. Toshiba sets do not have a card or board changeout!.. These peeps are crooks! A Toshiba set is repaired to componet level. It sounds like you may have a convergence problem or a problem inj the power supply involving the filter or couping capacitors. Seek out a pro whos an authorized servicer for Toshiba.
Sep 09, 2006 | Toshiba 42H83 42" Rear Projection...
Panasonic CT-36HX42 36" TV Logo
186 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
