H20 is a water warning. The machine THINKS it has no water coming in (Hence it continues to fill and fill because it can''t see the water). 99% of the time, this is a blocked rubber pipe that goes to the pressure sensor. Water in the drum fills the bottom of the rubber pipe and as the water rises, the air pressure in the pipe increases, which operates a bellows device in the pressure sensor. If the pipe is blocked, the pressure sensor won't operate and it will continue to try to fill until it times out. There COULD be a wire off the sensor or a wire that goes to the sensor loose on the main board, there could even be a failed component on the main board, but all of these scenarios are ar less likely than a blocked pressure sensor pipe. Take the lid off, pull the pipe off the bottom of the sensor, blow down it hard and this may well clear the blockage. Put the pipe back on the sensor and test. Come back if you need more advice
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
SOURCE: Water Does Not Drain
You may need to Clean out the pump catch to do this you need to remove the drain pump access cover, insert a pointed object (or tool) into the hole, Bottom right front of the unit push in to release the latch and rotate the cover clockwise.
you will need to clean this out use a shop vac to remove the water in the unit or have plenty towels handy
AS far as the fault code
E:04=Er:04washing=Door control broken
Cause=Faulty Triac or control module
SOURCE: Kenmore HE2T F20 plus Water leakage when tub starts to fill
Have you read by advice on how to diagnose this problem? Click on the following link:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
If you HAVE water entering the wash tub, first verify that you do not have a siphoning condition. This is where the drain line does not have the proper air gap to drain properly and creates a vacuum on the drain line. This will cause drain problems and may prevent the washer from filling all the way. Or, you may have trouble maintaining the water level. When you stated you had water leaking, is this a visible leak? Or, do you have water slowly draining from the tub? Double check your drain line to be sure.
Next, check the drain pump to ensure it is not clogged or obstructed which minimizes drain flow. Also, make sure the pump is running. Remove the access cover and clean out the pump reservoir. In addition, check the drain line from the bottom of the wash tub to the inlet side of the drain pump. I have personally found small articles of clothing stuck in this line, preventing drain flow.
Read through the link thoroughly. If you require additional assistance, please let me know before rating the solution. I hope this helps you.
SOURCE: Hotpoint wt740. When starting a
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing? This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent. Is "Sd" displayed and the wash cycle dial is not flashing? If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds. Is the drain hose kinked or clogged? Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work: NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
