Question about Vacuums
Replacement motor I purchase a replacement motor for a F5897-900 Hoover SteamVa Motor part # 43576197 or 27242051. The replacement motor has three electrical connectors + ground were as the orginal has two electrical connectors + ground. Do I ingnore the the thrid connector and hook up the wires to the same connectors as the orginal or do I have to do some rewiring.
    President:
  • 1,673 Answers
The manual only show one wire from the motor going to the switch, the other going to the cord, then the ground wire. I would wire it the way your old motor was, could be that some models maybe were 2 speed and the other wire would be used for that. Either that or the wrong motor was in the box, it is the right part number (43576197 is Hoover number)
Posted on Jan 29, 2008
Hoover F5915-900 brushes will not rotate
The motor rotates the bar. My guess would be that the rubber belt that goes from the motor to the belt has fallen off the bar , broke, or the bar is not seated properly. GOOD LUCK FRIEND.
Nov 13, 2014 | Vacuums
Can't hook up power cord to main motor on Hoover model F5915100
You have a black and white and green wire. Green is ground white is neutral, black is hot . Should say on the motor either L1 = black wire. L2 = white wire , G = Green wire or it say H = black wire, N = white wire , G or the symbol for ground = green wire
Apr 11, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover 5163 Fold Away
Cutting out the thermal protector is a way assuring a sale of a replacement motor in the near future.
Apr 04, 2014 | Hoover Vacuums
Hoover carpet shampooer is smoking and not working. Is the motor shot?
If it smells like an electrical fire, the motor will need replacement ( part # 43576197, msrp $74.99 ) + labor.
Jul 30, 2011 | Hoover F7431-900 SteamVac Vacuum
Brush on vacuum stop spining (HOOVER U-5753-960) Thank You
A worn out carbon brushes of vacuum will cause that motor spinning stop. Because brush no longer capable of pushing a stator or rotor hence electromagnet windings motor will not meet each other.
Have a brush replacement be customize in a nearby machine shop or find brush replacement on hardware store.
Look also for the possibility of loose wiring of the vacuum, check it also.
Thanks for asking.
Jun 26, 2011 | Hoover U5753-900 WindTunnel Bagless...
Burning smell and loud noise from hoover steamvac f5897-900
Perform general maintenance - cleaning filters,etc. If it still exists, take it apart and check the motor... If the motor is sooty on the copper coils inside, then it's had it's day. You could try and buy a replacement motor, but typically, its cheaper just to get a new hoover.
Jan 12, 2011 | Hoover F5897-900 SteamVac Upright Vacuum
Machine wont turn on
Either the motor is fried or the belt is burnt. If you can't hear it turn on, then check for any fuses that could have blown. They will be glass tube type. If fuse is good, motor or power supply could be bad. You can test them with voltmeter.
Sep 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Need manual
To all the users looking for this manual.
Check the links below:
Online User Manual and Guide for Hoover F6020-900
Regards.
Jun 29, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Vacuums Logo
151 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
