Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Blown lid assembly fuse and no spin cycle
A few weeks ago i replaced the lid assembly fuse. If blew out again now. Cahnge if and it blew out again. I assume i need a new lid assembly unit. Is there anything else I should check the confirm this?
Also, In the past the spin cycle would continue to work but now even this no longer works. Any ideas?
    Problem Solver:
  • 7 Answers
GET A LID SWITCH ASSEMBLY
Posted on Sep 24, 2009
  • jdn1105 Sep 24, 2009
    WHICH COMES WITH A FUSE PART # 27038
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
For the past few years the small fuse in the washing machine blew about once a year. A few months ago it seemed to blow every week. Then it was fine again. Now I replace the fuse and as soon as I turn on...
One says the lid switchs are not working in tandem with each other. Another says the circuit board is bad. I say it is because it is a Maytag and built with an obsolete ethical plan for generating profit.
Dec 29, 2009 | Maytag LSE7806A Top Load Stacked...
I hae a Whirlpool LSR8233EQ1 Top loading washer.
If you can catch it running while in the spin cycle but not spinning ( put a butter knife or screwdriver in the lid switch hole ) and wiggle the timer knob . If it starts spinning during this process , the timer needs replaced . Sometimes though , when a washer does everything BUT spin and you hear the motor running , the transmission is the problem .
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing machine won't drain
replace the lid switch. that's what i have to do with mine. i researched it a few weeks ago. Simple cheap fix - i think it was about $20
Mar 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Microwave humming
It's possible that it is a sign or trouble, but it will make seemingly odd noises when it is switched on and off. For the most part, you can wait until you see more definitive evidence of trouble. Watchful waiting is probably in order here for the next week or so.
Jan 07, 2007 | Kenmore 80882 Microwave Oven
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
149 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
