Sewing Machines Logo
Sandy Rockwell Posted on Aug 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you sew an Overlock stitch using yarn?
I have baby yarn and I need to sew on flannel
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Aug 25, 2015
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2613617
Points
59176
On a serger, you can only install larger threads in the loopers--but use regular thread in the needles. You can also use a cording foot, feed the yarn through the groove in the foot and overlock the stitches over and around the yarn.
Crochet patterns using bernat baby blanker yarn
Hello, Leona -
You will find 8 crochet patterns using Bernat Baby Blanket yarn here:
https://stitch11.com/8-free-crochet-patterns-that-use-bernat-baby-blanket-yarn/
This web page touts 26 patterns:
https://www.allfreecrochet.com/Crochet-Afghan-Patterns/Bernat-Blanket-Yarn-Patterns-That-Are-Too-Cute-to-Miss
You can find more patterns by using your favorite search engine (Google, Bing, Yahoo Search, etc.) and the following search phrase, using quotation marks as shown:
"Bernat baby blanket yarn" "crochet patterns"
Best wishes.
Decreasing single crochet stitches
There are several ways of decreasing crochet stitches, but the pattern should indicate what stitches to use. The most common (or easiest) is to yarn over in the first stitch (do NOT pull the rest of the stitch through) and then yarn over into the second stitch and pull the final stitch through both yarn overs.
How to Decrease Single Crochet dummies
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
What does t mean marke in knttig pattern
In your knitting instructions there must have been some indication that a stitch had to be marked. Like a piece of contrasting yarn to make the stitch stand out. Now they are referring to that particular stitch.
1helpful
Serger stitch not forming right
It sounds like the timing needs to be reset by a sewing machine repair tech.
1helpful
2answers
Jams
I make flannel square quilts for babies, it is a nightmare itself. It makes a lot of lint in the bobbin case and under the face plate, try prewashing the fabric before using it and clean out the bobbin case frequently while sewing. When i dont prewash it, i just open the bobbin area and blow the cotton dust out with my breath or i use the small brush to clean it out
2helpful
My Evolve serger is skipping stitches while using the 4 thread safety stitch which is a chain stitch with a two thread overlock. Sews fine for a few stitches and then skips a loop which unravels. I checked...
First, change the needles making sure to use the el705 needle system. Second, make sure the subsidiary looper is engaged properly (plugging up the upper looper hole). Also make sure the needles are all the way up in the machine. This should do it or it may need to be adjusted but the Evolve is a very, very reliable machine. Hope this helps...
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
