Question about Canon Pixma MP500 All-In-One InkJet Printer
Ink Tank Error
I keep having the "Ink Tank Error" or the "two of the same color" or the "can't recognise ink tank" error messages. The ink tank is almost brand new so I know it isn't that. In your archives there is a fix for this on a different model, but it calls for hitting the resume button 4 times, mine doesn't have a resume button.......can you please help, I have a project due very shortly and I'm up against the wall on this one.
Ruthann
  • 10 more comments
  • ROP98101 Dec 02, 2007
    Same problem (U150--ink tank cannot be recognized) in a Canon MP610.  Had been working fine.  Tank is half full, at least.  Removed and replaced tank several times.  Turned printer off and on several times.  Printer is one month old!
  • scarlet44 Dec 09, 2007
    same problem with the canon pixma iP4500. I've taken it in an out several times, but it gives me the same error message. It will finally work when I turn the printer on and off.
  • Anonymous Jan 16, 2008
    Yes same error! But I have a brand new Canon MP610. Every time I go to print gives me the message of Doe not recognize C ink tank. I have taken it in and out turned the printer on and off and still can not get to print.
  • Anonymous Feb 24, 2008
    Same here. Two months old mp610. I usually get it working after turning it off and on again
  • Ruthann44 Mar 27, 2008
    My solution to the problem was to call Canon and they sent me a new cartridge.
  • AzLobo Apr 10, 2008
    I have Canon MP610 printer and I continue to get the U150 error - "ink tank cannot be recognized".  At first I could solve it by turning the printer off and on a few times.  Now it will not go away, even if I completely power off the printer.  This is a new printer and has only had limited use.  Very frustrating.
  • afriend000 May 18, 2008
    Canon IP6700D same issue. Apperently Canon has this across the board with their new carts
  • samgef May 26, 2008
    I changed the ink cartridges last week and now I get the alarm light with the error code U043 "tank cannot be recognized." I held the stop/reset button for at least a minute, I have shut system down and restarted with no luck. Any suggestions? Thanks.
  • Anonymous May 27, 2008
    Keep getting, two of same ink color installed~
  • Anonymous May 28, 2008
    First the magenta ink ran out-I immediately replaced it. Now I keep getting a message that it can't print because there are 2 of the cyan cartridges-
  • joerisboy Jun 01, 2008
    Same problem with Canon MP530. I bought Original Canon CLI-8 ChromaLife Pack an changed all 3 colour inks.
    I cannot print because it shows U071 or U140, but all inks are at the right place and full. :-(
  • Anonymous Jul 29, 2008
    I've had my MP500 For a couple of years with no problem. All of the sudden, my Magenta ran out and said to replace, but then I kept getting an error U150 , unable to recognize 8BK ink cartridge or that I had 2 cartridges. The 8BK is full. But I got the error for about a month, I just replaced the magenta and the black and the error finally went away. I think I will call CANON to get a replacement black, because other wise I just wasted money.
The problem here is not so much the ink tanks (although that could be a cause), but the contact pins in the printer that touch the gold areas on the little pc card that is on the cartridge. Remove the cartridge, use a probe (or in desparate situations a finger), and feel for the contacts at the front of the cartredge carrier (stick the whatever into the slot that is left when you take the cartridge out of the carrier), and gently pull them upwards. Presto! the cartridge should now work when you put it back into place. You might have to bend the pins upwards a couple of times to get this fix to work, but it sure beats calling Canon every time a cartridge gives these errors! Good luck...
Bill
Posted on Nov 02, 2008
I called Canon.  They were great.  They sent a replacement cartridge immediately.
Posted on Apr 12, 2008
I used a Q-Tip with a little amount of car polish to buff up the electrical contacts on the chip of the cartridge.
So far it has worked.
I have the same problem to, dont know what to do!!
Posted on Mar 26, 2008
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
Color tank isn't installed --- but it is!
Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
Nov 07, 2009 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error messages: U150 + Ink tank errors have occured
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Jul 12, 2008 | Canon PIXMA MP600 all-In-One InkJet...
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Canon Pixma MP500 All-In-One InkJet Printer Logo
509 people viewed this question
old marine
old marine
