Question about Ricoh Aficio 2015 Copier
Our Canon ImageClass D860 copier had a paper jam. We cleared the jam and did everything we were supposed to do and it still says Paper jam on the screen. We've turned it off, unplugged it and still it says Paper Jam.
  • Ricoh Master
  • 6,763 Answers
There mite be some paper dust on the sensor where the copier indicate the paper jam is. some can air mite solve the problem. Be careful to direct can air towards the outside of the copier don't want to blow the paper dust to a different sensor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 13, 2009
No Image on copy after paper jam
Maybe problem with the scanner,see if it mooves
Jun 20, 2015 | Canon imageCLASS D860 All-In-One Laser...
Canon imageCLASS D860, starts fine feeds paper through toner end then stops half way through. Sytem shows paper jam, but paper just stops moving. I can open it and lift paper out. paper wt. 20
try cleaning the pick-up and feed rollers with alcohol and see if that takes care of the problem. if it does for a short time that you need to replace those rollers
Feb 19, 2011 | Canon imageCLASS D860 All-In-One Laser...
Paper jammed at exit rollers of Canon D860. Paper
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
May 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
Paper jam!! gets caught in roller! help please!!
Remove jam, again. soft damp cloth, gentle wipe rollers at front, no hard pressure.
Continual jams usually are the result of purchasing cheap paper, I used to do the same, learn't lesson, only a few pence more, saves all the swearing and hassle of fiddling around with jams when you have more important things to be do?
Further tip, before placing quantity of paper in tray, holding paper firmly, twist in opps directions, this helps seperate the sheets of paper that may stuck together.
Nov 12, 2009 | Canon imageCLASS D860 All-In-One Laser...
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Paper jam
remove slowly the cover so that you can get slowly the piece of paper.
Jun 08, 2008 | Canon imageCLASS D860 All-In-One Laser...
Paper jam
What that sounds like is misfeeding.
Remove your paper tray and take a soapy cleaner, like formula 109 or fantastic and thoroughly clean the rollers.
If that helps and it statrs misfeeding in a day or two, you probably have slick rollers.
Watch inside the paper feed. Make sure the paper is going against the rollers then see if they just spin on the paper.
Mar 27, 2008 | Canon imageCLASS D860 All-In-One Laser...
Error Message - System Error E000
Does a page come out? just blank? How old is your cartridge, did you pull the tape out? Need more info to help.
Aug 28, 2007 | Canon imageCLASS D860 All-In-One Laser...
Ricoh Aficio 2015 Copier Logo
397 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
