Question about Boating
1987 225 Evinrude will not stay idling. Will start every time it shuts down; however will only last 5 seconds or so. Only difference in last week was filling with gas and adding octane booster. Any suggestions? Has new plugs Runs fine above idle
  • Steve Baird Jul 20, 2009
    Will idle fine with hose hooked up:however when in water it dies immediately. Confusing.
    New Friend:
You have 2 options you either need to replace the power pack which is most likely it or raise your idle a lil bit
Posted on Nov 21, 2012
  • handyman8128
    handyman8128 Nov 21, 2012
    you have 2 options you either need to replace the power pack which is most likely it or raise your idle a lil bit
I have a 1988 225 evinrude that will not stay running unless I keep pumping the primer ball. I installed a new VRO pump so I dont think its the pump,it just keeps losing its prime in the ball
Posted on Apr 13, 2011
  • 57 Answers
Is your idle speed high enuf? have you checked timing-i know sounds silly but
Posted on Jul 13, 2009
1987 Evinrude E60TLCUC start and will idle but,when trying to icrease speed engine shuts off. I can keep a slow idle speed.
If that has a carburetor then the main jet is clogged and it is running simply from the idle circuit - ergo carb has to be thoroughly cleaned out. . If it is EFI then the hassle could be with the control board that controls the timing. If the timing is not advanced when you rev the motor it will shut down.
Jul 05, 2015 | Boating
Evinrude will not start
Bad gas is one thing, 2nd may be dirt in carbs, 3rd fuel filter etc. May cracks in prime bulb. Lot of little things happen when set for some time w/o running. good luck
Dec 07, 2017 | Boating
I own a 1998 mazda 626 last week had the alternater changed and the car ran good for about a week now the car will start sometimes and sometimes it wont but when im driving it i have to keep the gas p
Engine stalls cold or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 05, 2012 | Cars & Trucks
2001 4.0 ford. Engine has had rough idle at cold start up for a few weeks now it will only attemp to start up but shuts down in 5 or 6 seconds. can any one help with this problem I'am having.
Is your check engine light on? if so have you had the codes read? If not have it done and post the codes here. cannont conclusively say what is causing that until that is done...
Jun 09, 2012 | 2001 Ford Explorer
1992 Lexus S300 Automatic. Car drive perfectly fine. Problem is sometime when I start the car, it should idle and shut off within 5 seconds. Doesn't happen all the time, just sometimes. Sometimes it d
Without any other symptoms it is hard to diagnose; could be water in the fuel or a plugged up air filter, that effects idle first, take it out and see if it idles fine, if so get a new one. Take out fuel filter and dump in a glass bowl and analyse for water... get a new one... Is it different when the engine i hot or cold?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_573a00ba7e399076
Dec 05, 2011 | Lexus SC 300 Cars & Trucks
I have a Vizio 42 in LCD, model VO420E. The TV makes a loud screeching noise, the screen goes crazy and then shuts off and starts again. There sometimes is a pop. Other times the TV just makes the POP...
Hi well what's happening is that the "Protection circuitry" in the SMPSU has/is detecting a potentially catastrophic fault, and to stop a fire AND EXPLOSION OR INDEED BOTH, IS ATTEMPTING TO SHUT THE SET DOWN FOR SAFETY REASONS, HOWEVER AFTER IT SHUTS DOWN, THE "FAULT" APPEARS TO "GO" AND THEN THE SMPSU STARTS UP AGAIN , ONLY TO DETECT THE FAULT AND SO ON... USUALLY ENDLESSLY OR UNTIL COMPLETE FAILURE OCCURS.
What to do, well in all reality DIY is NOT feasible unless one has LOTS of experience, test gear, tools, isolation transformer, and a service manual. So, contact the local or head office from VIZO, ask them for a referral to an authorised service center, hopefully a local one? in any event, make face to face contact here and ONLY ask first for a "Quote" as to prospective costings and go from there, this way at least you can make up your mind as to repair or replace?
Sep 25, 2011 | Vizio VO420E 42 in. LCD TV
2004 nissan quest DTC P0507. Can't get IAVL to
My quest 2004 idle below 500, start up then off, have to start couple times when the engine is cold. when i pushed the gas pedal, it smells gas.
Oct 21, 2009 | 2004 Nissan Quest
97 Chevy Truck starts and idles rough and then shuts down
Sounds like you're loading up with fuel. I'd check the fuel pressure regulator. Some engines are set up with a regulator inside the intake plenum, which requires plenum removal.
Oct 01, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
TV turns on and off constantly.
this is the heat detection circuit that detects to much heat in the set , cleaning the inside of the set of lint , dust , ect may stop it or it has just been dirty to long and that circuit will now have to be replaced
Nov 25, 2008 | RCA HD52W59 HDTV Projection Television
Boating Logo
521 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
