Perhaps this video will help:
How To Sew Blind Hem Stitch 2
Unfortunately, after reviewing your machine's manual, your manual does not indicate that your machine provides a blindhem stitch. The blindhem stitch generally is a stitch that takes several straight stitches and then zags to the left to catch the garment fabric. You can, however, use a zig-zag. You will just have more stitches into the garment that may show on the right side.
SOURCE: How many foot for Baby lock E5280 like flat, blind, rolled hem?
i dont have a baby lock but on my machine i change from rolled hem to flat needle plate
or change setting to n from r also loosen lower looper tension as rolled hem requires a tight lower looper tension.
hope this helps you
mary h
SOURCE: Need to know how to set the tension to sew hems on
Re-thread the machine and make sure that the needle is in properly. The tension would not cause the thread to break.
If it is not working, what is the machine doing? Try re-threading the
machine again, check the needle to make sure that it is in correctly.
There are no set numbers for tension- it is a feel, push, pull. If you
could e-mail me back with a better description of what the machine is
doing or not doing,
SOURCE: When buying a sewing machine
it means there is a foot included that will straight-stitch a certain number of stitches then do a zigzag stitch to the left that will catch the fold of the fabric at intervals. The fold is made at the width of the hem you want. When you finish and straighten the hem out, the hem stitches will barely be visible on the top side unlike straight-stitching across the top of the fabric. There will be a "hem stitch" option on the machine and the foot will possibly have a movable guide that runs along the fold of the fabric to where your zigzag "catching the folded fabric" stitch is consistent.
SOURCE: what are the settings for a blind hem stitch?
I downloaded your manual for free at www.singerco.com and I be darned, I see why you are baffled. Call Singer at 1-800-4singer and ask them to tell you. This is a first for me to see in a machine that is not that old, my 45 year old Kenmore has the blind stitch setting. There has to be some answer to this.
SOURCE: I cant get my 1034d to sew blind hem stitch
It is not a special stitch, just a three thread overlocked seam with left needle but you do it with the blind hem foot and fold your fabric into a "z" shape, wrong side upwards and raw edge at the bottom to be trimmed by the blade as you seam. The folded edge is run against the "blade" of your blind hem foot to ensure even "bite" of the upper fold by the needle while the loopers form the seam around your raw edge below. Then when you finish and press the z fold open, you obviously want a little as possible of the needle stitch to show on the right side of the hemline. So you need to practice and adjust the position of the blind hem guide to ensure you are getting the needle to stitch just onto the folded edge.
I have only ever done it on knit fabric, as it does show and not very successful on a curved hem edge, straight edge is fine. You only want to catch a minimal amount of the fabric with the needle, lengthen the stitch length to 3 so there is less stitches per inch as it will show on the right side.
There is a tutorial here on youtube http://www.youtube.com/watch?v=aDJbFNZrCUI
