Question about Tappan TGF351ES Range
Tappan gas range model TGF316GS Blowing knobs off
Tappan gas range model TGF316gGS:
When a tenant move out I turned the propane to the stove on and it blew all the knobs off. I replace he regulator on the propane tank. The knobs are still being blown off. What do I need to replace. The regulator on the stove? The controls?
Thank you
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
  • 1894 Answers
SOURCE: Tappan TGF351 oven burner adjustment
instruction to convertsion?
what you mean ?
Posted on Feb 06, 2008
  • 109 Answers
SOURCE: old tappan in counter gas stove/range
sorry, misinformation, no such child lock existed in those days, either your spark module is bad or your switches are bad, (unusual for all switches to fail simultaneously)
Posted on Apr 03, 2008
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
heatman101
  • 43501 Answers
SOURCE: how to adjust gas regulator
The center part of the regulator...
Make sure that you have the gas turned off...
Then turn the center part out and flip it up side down and then turn it back in till it seals...
Turn the gas back on and then check for leaks with a dish soap and water solution... if it blows bubbles it is leaking...
Heatman101
Posted on Mar 05, 2010
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
Tappan ES 200 burner stays on high and not turning off.
I need to clarify a bit.... did you remove the knob and check where the metal rod inserts into the plastic knob hole? If that is chipped on the inside, it will not turn the metal rod that comes out of the stove. Take the knob off, and use a pliers to turn the metal rod. Leave me comment if you have already checked that or you do not have that type of knob on your model.
Nov 17, 2009 | Tappan TGF320 Gas Kitchen Range
When i start my oven in mt propane stove goes puff
disassemble and **** orifices and clean , spiders etc plug up all the time , propane is nothing you want poofing when igniting!
Aug 23, 2009 | Tappan MGF500PBW Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Natural gas to LP converters
Your Tappan dealer can help you with this. You have a good named unit so it shouldn't be a problem. You could also check with your gas company as to where to get the conversion parts.
Feb 05, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan gas range 50 deg. too hot
I was unable to find a photo large enough to see if this range has stove-front knobs or electronic controls. If it is equipped with a knob for oven control, pull the knob off and peer into the shaft to see if a slotted adjustement is visible. If so, you will need a small-bladed, long shaft screwdriver to reach and adjust it.
Jan 08, 2009 | Tappan TGF320 Gas Kitchen Range
CONVERTING TO PROPANE FROM NATRURAL GAS
just need to change out orifices in gas line natural gas company should have new ones in stock
Aug 23, 2008 | Tappan TGFS_63 Gas Kitchen Range
Tappan Gas stove
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF351ES  Range Logo
417 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
