Question about ViewSonic VA720 17" LCD Flat Panel Monitor
POWER SUPPLY LOST
Need a power adaptor for a VA720. Do you know what Voltage and Amps it needs? Can I find one to cross reference and use from another supplier?
  • fcom45 Jul 12, 2009
    IS a single pin not 4.
    It is a single pin
  • 336 Answers
You need 12V, 4A.. below link may help..
http://cgi.ebay.com.my/ws/eBayISAPI.dll?ViewItem&item=250056242010
cheers!
Posted on Jul 12, 2009
Lost power cord
I believe that you would be ok. Voltage has to be "Spot on." Amperage, however, needs to "meet or exceed." Think of Voltage as pushing something into something. Think of Amperage as pulling something out of something. It won't draw more amps than it needs, even if they are available. Allow me to thank you for including the powerpayless website as until your post I didn't know what voltage I was looking for. Exactly the same thing happened to me with my SimpleTech 1TB. Perhaps we both solved eachother's problems. PS: I'm going to check with Radio Shack for a 12v adaptor with at least 3.5 Amp capacity. They might can beat the $30.00 which is what the above mentioned place gets including shipping.
May 16, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
I lost the wall plug and I do not know the output of the handheld cobra micro talk charging stand model # ga-cf S/n t606a14731 How do I replace wall plug or the voltage outage
looks like it's a 12V power supply. You should be able to go to Radioshack and buy a 12V DC power supply (Us in the trade sometimes call them wall worts). Take the device in with you to make sure that the plug style is the same.
May 14, 2012 | Electronics - Others
Have a flat screen viewsonic with no adapter cord. Takes a 12 v 3.3 amp. What would happen if I hook up a 12 volt supply with more than 3.3 amps? Thanks, Tom
Higher current is OK and better than not having enough and it does not do any damage, voltage cannot be higher.
Just think of it like a AAA and AA batteries, both have the same voltage but AAA has less current capacity.
The power supply must be regulated 12vdc though, which will be switch power supply type and also observe the DC plug' polarity (center positive).
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 19, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
I lost the power supply and would like to know what voltage and amps in need in a power supply to operate the maxtor
Power Requirements
AC Input Voltage: 100–240 VAC
Input Frequency: 47–63 Hz AC
here is a link to the manual : http://www.seagate.com/staticfiles/maxtor/en_us/documentation/data_sheets/onetouch_data_sheet.pdf
Oct 30, 2009 | Maxtor OneTouch A01B080 80 GB Hard Drive
What voltage do i need for my ViewSonic VA720
Monitors and PCs (amongst other things) use a fairly standard power cable. You should not need to worry about the specifics as there is generally no transformer needed for a monitor.
Oct 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Upgrade for Bestec ATX-1956D (HP p/n: 0950-4106)
How about the LC Power LC350M Micro ATX - 380 Watt
or the
Logisys 350W Micro ATX
They should fit your form factor and output as much as 350W being relatively cheap, but neither gets 18 amps on 12V rail...
I think no power supply of that size has an output like that...think about a cheap but substancial chassis upgrade if you need that power...Have a look at directron for the PSUs.
Feb 13, 2009 | HP Bestec ATX-1956D 200w HP Part No...
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
247 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
