Question about GE Refrigerators
Continuous clicking noise and will not cool
The problem began two years ago. The clicking was annoying but it still could be regulated temp wise. I disconnected (bypassed) the sensor in the top LED panel and that stopped the clicking. Then two years later the clicking began in earnest. Now it will not start the compressor at all and will not cool. The LED works to the point where when you set the temp as warm as it will go it displays the off message. Nothing will start the compressor. I suspect the sensor being by passed may have eventually caused the failure of the main board. It is purely electronic in nature. You can tell it is trying to tell the compressor to start up and then sends a message it is cold enough so it clicks (trying to start but not starting). Seems this is a problem with this unit.
  • kbhope123 Jul 12, 2009
    the model is pds20mfsb
    serial ll056569
    Where is the main board located? I assume it is not the board in the LED unit in the top of the fridge part. Also I assume if I buy one and replace they will not take it back if it fails to solve the problem. Would my bypassing the sensor in the LED unit cause a problem and if it was not the problem why did the fridge work properly after I disconnected/bypassed it two years ago? Do I need also to replace that sensor?
  • 6,784 Answers
HI, Rule number one. Never bypass the sensor in this type of unit. This issue, originally, concerned the actual Main control board(PWB). There is a major issue concerning the circuitry of this board and, it should be replaced asap. Now, concerning the no start issue of the compressor unit. this is the result of a failed P.T.C Relay(start relay). This device receives the signal from the main board to activated the compress, via PWB DISPLAY ASM(Interface). It has failed.
I recommend replacing the following parts. these replacements will restore your unit.
P.T.C RELAY-- WR07X10086-- $61.50
BOARD ASM MAIN CONTROL -- WR55X10656 -- $183.25
SENSOR -- WR55X10025-- $14.25
**NOTE--(The main board is usually found on the middle or, lower backside of the unit. The most common spot will be located near the compressor unit or, just above it in the back mid section of your unit.)
Posted on Jul 12, 2009
  • 3,230 Answers
First of all you need to provide me the make and model number of your refrigerator.
Well, It seems like the main board failure...
Please post back further details.....
Thanks
When car gets to normal operating temp it shuts down will not restart until cools off
Not necessarily. There was a re-call on the cooling system a few years ago. Check with your mechanic about that. ------------------------------------------------------------------------------------
Digiprog3
Dec 20, 2012 | 2001 Dodge Intrepid
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Clicking noise under dash
It likely has a bad temp control actuator for the blend door.
May 27, 2009 | 2000 Lincoln Town Car
Very annoying squeaking / creaking during agitation
sounds like trnsmission and brake assembly they are not cheap. you can see one at www.repairclinic.com scroll down to the red(100) click it and look for part number 279566.
Apr 06, 2009 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
I have a 1998 Jeep Grand Cherokee 5.9L, and recently, the vehicle has developed a tapping sound in the front passenger dash near the A/C vent. It began as just an ocassional tapping, and then became more...
Check engine oil level and confirm engine lubrication. Could be the tappets clicking due to not enough oil up there. Does noise go down as engine heats up?
Aug 26, 2017 | Jeep Grand Cherokee Cars & Trucks
Canoscan 4200f clicking noise when turned on
Cool. I bought the scanner 2-3 years ago and i had the same problem. I gave it back, received a new one ... exactly the same noise ... on 3 different computers. **** product!
Jul 30, 2008 | Canon CanoScan 4200F Flatbed Scanner
Kenmore - Constant humming, clicking sound
ok if little or no cooling suspect defective relay/overload combination.
Mar 25, 2008 | Kenmore 44103 Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
