My princeton VL1918 is about 2 years old. It started blinking today. I tested it on a 2nd computer and it still blinks. It even blinks without a computer signal. Can this be fixed?
The problem is more than likely the caps in the powersupply have gone bad. What you need to replace are 3 470uF 25V (you can use 470 uF 35V caps too) capacitors on the power supply circuit. Yes, you will need to bring out the soldering iron, no it is not terribly difficult to unsolder them. There is a longer thread on here (search under vl1918) for more info in which I posted a solution that has worked for most.
It may need a different outlet, if it is not getting proper power. Small chance that the video cable has gone bad, but more likely the monitor is damaged. But try those two things and call Princeton.
Was this helpful?
Yes
No
Popular Solutions for Princeton Digital VL1717 LCD
Trying to install Princeton VL1717 to my compaq/hp running XP. When first connected image appears...
(More)
Trying to install Princeton VL1717 to my compaq/hp running XP. When first connected image appears and then cuts out after about 3 seconds, will not come back unless unplugged or turned off and then it is gone again in 3 seconds...Is it a driver issue? Resolution? Help!
the picture does not center in the screen. there is a black section between the left side of the...
(More)
the picture does not center in the screen. there is a black section between the left side of the screen and the picture. the horizontal hold only brings it part of the way there
I have a Princeton VL1717. The monitor goes black. When I press the on off repeatedly it comes on...
(More)
I have a Princeton VL1717. The monitor goes black. When I press the on off repeatedly it comes on then turns off again. The intervals are varied form a few minutes to an hour or more. Is it the switch? I have a differnet model princeton that was going off and on. But I changed 3 capictors as recommended on this forum and it works fine now. Could this be a simalr issue?
