Question about Canon Rebel XT / EOS 350D Digital Camera
Canon Digital rebel EOS, purchased april 2004. Mid session, the camera started to take pictures that were blank on bottom 3/4 of frame. Boundary between black and normal portions of picture are fuzzy, not a clear line, LCD works, displaying normally on images taken prior to malfunction. Downloaded pictures present the same way. I cycled camera on and off, tested and reformatted 1GB CF card. No difference. HELP
  • 2,200 Answers
Hi
Unfortunately this may be a CCD failure and the camera will have to go back to Canon for service.
However you can try the following and if you are lucky you may get a result
1) Reset the camera to default settings . To do this - enter the menu under the Wrench Icon,T,2 Tab. Press the directional keys to select Clear All Camera Settings and press SET. Press the play key to select OK and the camera will reset to Default settings.
2) Power off the camera and remove the batteries for 30 seconds. Ensure all terminals are clean - replace batteries and power up. This forces a reset.
As I say if this fails there is likely a component failure and camera will have to go for service.
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 12, 2009
Top half of the picture is taken
Your shutter and mirror are out of sync.
Jul 17, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I have a cannon Rebel EOS and when I take pictures I have to look through the view finder they dont come up on the screen
That's normal. The Digital Rebel works as SLRs have worked for half a century, using the viewfinder to frame and compose your pictures. Only the more recent dSLRs have the Live View capability to allow you to use the display to frame and compose your pictures.
Apr 06, 2010 | Canon Digital Rebel / EOS-300D Digital...
Canon rebel 2000 EOS pictures are cut off by 1/3
shutter problem, cut off is part not exposed,replace the shutterunit.
Mar 07, 2010 | Canon EOS Rebel GII with 35-80 lens 35mm...
Display only works after the shot canon eos rebel xt
The XT does not have a live view capability. It works as SLRs have worked for half a century: you frame the picture through the viewfinder and click the shutter.
Or are you saying that you can't see the menu on the display?
Feb 09, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Rebel XS was working fine... yesterday, all of a sudden, the LCD screen went blank and it displays 'busy' when trying to take a picture. Recharging the battery and replacing the sd card didn't change...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Nov 30, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
My canon xsi digital camera is not functioning the way it should.
This is normal for an XSi. What might be causing this:
-Picture setting producing huge picture files (RAW vs JPEG) -SD card not of same class, try using a faster card, such as a Class 6 or 10
Apr 17, 2009 | Canon EOS Rebel XSi Digital Camera
I have Canon EOS 300D digital Rebel. I have had intermittent problem with the camera display screen going blank even though I put a freshly charged battery in. Usually I can take a couple pictures then the...
Strange, intermittent problems with the EOS Digital Rebels can be caused by a defective shutter release switch. We charge about $85 to replace it.
Nov 12, 2008 | Canon Cameras
New canon eos digital rebel xti
There have been several reports of CF cards that work with all cameras, except the Rebel XTi. It depends on the actual manufacturer of the card. Canon made a change mid-production that affected the data saving. Try another brand of card & you should not have that problem any more.
Jun 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
