Question about Tefal Ultraglide FV3266003 Iron with Auto Shut-off
The auto safety light is on how do I get the iron to work again?
Move it genly
Posted on Aug 18, 2009
HAVE A SHARK IRON THE GOES INTO AUTO SHUT OFF EVER SO OFTEN BUT HAVE TO UNPLUG AND PLUG TO GET GOING AGAIN IS THIS THE WAY IT WORK
A lot of irons turn themselves off if left unattended. This is a safety precaution (to keep the house from burning down).
http://www.sharkclean.com/manual/EP480CS_REV_1104A.pdf
Sep 14, 2017 | Irons
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
Hi the auto shut of light came on and I cannot get the iron to work, keep switching off and on over the past week to no avail.
It's a safety feature that we can do without. But keeping the Iron moving will keep it hot.
May 19, 2016 | Irons
IRon heats standing but the light goes out when I set it horizontal to iron a garment. I think the cord is needing replacement but need advice.
If the iron is not moved while it is plugged
in, an internal safety switch will turn it off.
- It will turn off in 8 minutes if left vertically or
in 30 seconds if left on its soleplate or tipped
over. A red flashing light indicates that the
auto-off has been activated.
The above information is from the Rowenta DX1700 Owner's Manual. I think most, if not all Rowenta irons have the "auto off" safety feature. If your iron is going off before the 30 seconds idle time, the sensor may be defective. If you are letting it sit on the sole plate longer than 30 seconds, you may just need to work faster. ;-)
Jun 11, 2011 | Rowenta Irons
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Iron won't heat up!!!
A lot of rowenta irons have a safety or auto shutoff built in them that fails. The only way I have found to fix them is to disassemble it and permanently connect the switch then it works fine, just does not auto shut off.
Jan 14, 2009 | Rowenta Power Duo Iron
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
the only thing you can do is change out the motion sensor which is 1n the machine or disable it
Apr 21, 2008 | Irons
B&D steam xpress 660 faulty switch to replace
I'm not familiar with your particular model , or Irons themselves.
So forgive me if im wrong ,
I think it could be a safety feature , to prevent accidents, so replacing the switch will most likely make no difference.
But if you still find yourself needing to Iron sideways , possibly whilst extreme bungee-jumping or entering the earth's outer atmosphere !! LoL sorry couldn't help myself there , you could try phyically bypassing the switch itself.
There would be two main ways to approach such a task, depending on the cut-out system utilized by the iron.
[u]Electrical diversion[/u]
Usually safety cut-out switches will interrupt the power of one polarity only, either positive or negative. especially where water is involved. This is easily bypassed by simply joining the matching 2 wires together either side of the switch to complete the circuit making the safety switch obsolete. There may be other wires for indicator lights ect which are better left alone for now.
[u]Mechanical diversion[/u]
The iron may utilize the water or other moving component to interrupt the power supply .Such as a water level indicator in a kettle, which is positioned to activate only when in sideways position. Again you could bypass the wires as above or bind the mechanism to prevent the movement being possible.
If it does use the water method , running the iron with no or low water in it may work...But there's probably a safety feature for that too....LoL
Anyways hope it helps you out a little
Feb 06, 2008 | Black & Decker Steam Xpress AS250 Iron...
Tefal Ultraglide FV3266003 Iron with Auto Shut-off Logo
240 people viewed this question
Top Tefal Irons Experts
Norman Worley
Marvin
Marvin
Are you a Tefal Iron Expert? Answer questions, earn points and help others
