Question about Sony Playstation 3 (PS3) Console
How can i connect to my ps3 using a 3 usb modem on vista ? :(
My ps3 works when i use a wireless router but when i connected my ps3 via ethernet cable to my laptop it wont work :( can someone please help and can you explain step by step as im dumb (:
  • 105 Answers
Make sure your PC is sharing the internet connection with other networked machines. Right-click on the connection and then click on Properties. There should be a sharing tab where you can enable it.
Posted on Jul 13, 2009
My ps3 won't connect to my TP-Link TD-W8901G. no matter what I do, the wireless won't work.
Try connecting the PS3 to the router via ethernet cable, their may be some buttons with numbers on the back of your router, one the PS3 is connected press one of these.
the PS3 should know the paired with the router and the wireless should work.
hope this helps!
Mar 02, 2011 | ASI TPL WL RT TDW8901G 4Port 54M Router
I cant get my netgear N300 wireless router to work with Netflix on Playstation 3. says ethernet not found on tv
ethernet not found means there is no connection via the cable to the router.
have you configured the wireless settings on the ps3?
Feb 27, 2011 | NetGear Computers & Internet
Wireless connection works fine from the d-link router but the desktop linked from the phoneline keeps going offline. Why?
You've omitted some information about your hardware & configuration & connections.
You should have:
1. cable-modem connected to cable socket (or DSL-modem connected to telephone wall-jack);
2. router connected via Ethernet cable to the cable-modem (or DSL-modem)
3. desktop computer connected via Ethernet cable to the desktop computer
4. wireless device (iPod or netbook or notebook) connected over the "ether" to the router -- this connection will stay "up" almost "forever" (as long as there is AC-power to the router and power to the wireless device).
Which parts & connections do you have?
Dec 26, 2009 | D-Link Computers & Internet
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
Im trying to connect my ps3 to my wireless router. it has recently stopped working. is there anything i can do?
Sure! Try this:
1 Turn your network off. Modem router, computer, printers etc. turn them off.
2. Leaving the wireless router connected to the modem with an ethernet cable (modem power off) , turn your wifi router on and let it cycle up.
3. After the router is cycled up, turn power on to your modem , leaving the ethernet cable connected to the wifi router's internet port. Let the modem cycle up .
4. After this, turn on all computers, routers and etc... no particular order.
This should allow your modem to find the wifi router and direct it to your computer via wifi or ethernet..
Dec 08, 2009 | Computers & Internet
If you dont have a router can u still use a cricket usb modem
with a laptop connect the laptop to ps3 with an ethernet cable and on the cricket modem connection goto properties and turn on connection sharing and choose the local are connection as device to share with
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
My XP computer is a wired connection to the modem. The XP computer is supposed to be a wireless connection to the modem. That said, why is it that when setting up the router, I am instructed to plug in...
It's not really required to plug in your PC via ethernet cable to the wireless router in order for you to configure it. It is however, recommended to connect it via ethernet cable initially so that when you changethe wireless settings on the router you wont get disconnected. Please note, that when you connect your PC wirelessly all wireless settings should match (Wireless Name/SSID, Wireless Security (WEP/WPA keys or passphrase), Wireless MAC Filtering).
Jul 14, 2009 | Linksys WRT54G2 Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Sony Playstation 3 (PS3) Console Logo
177 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
