Question about Cycling
Need to remove the cable from the 105 flight deck
  • 34 Answers
This really depends on what cable you need to replace, the brake or the shifter.
For Shifter:
1. Shift the all the way down to the lowest gear using the small inside shift level for both the front or rear.
2.Disconnect the cable from the derailluer, likely a 5mm allen wrench will be needed.
3.Pull housing away from the shifter exposing the cable where it enters the shifter.
4.Compress the brake lever, this will expose a small hole on the inside of the shifter where the cable head is seated. For the right shifter the hole will be on the right, for the left shifter the hole will be on the left.
5. Push the cable in from where the cable entered the shifter. The head of the cable will now be exposed.
6.Pull the cable the rest of the way out of the shifter.
7.Install the new cable.
For Brake:
1. Disconnect the brake cable, likely with a 5 mm allen wrench.
2. Compress the brake lever. Keep it compressed until step 5.
3.Look straight in from the front of the bike, you will see the head of the brake cable.
4.Push the cable out of the shifter from the exposed area of the cable, then pull once you can reach the end of the cable.
5.Install a new cable.
Depending on the reason you have removed the cable, it is advised that you also replace the housing in most cases. For the shift cables this is not a problem, however, for the brake cables you will have to untape the bars to access the housing.
I hope this anwsers your question. Thank you
Posted on Jul 17, 2009
2 Suggested Answers
  • 484 Answers
SOURCE: shimano 105 flight deck diagram?
If this is not the diagram you are looking for, please check techdocs.shimano.com for the proper one.
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/CycleComputer/SI-0045A-001_v1_m56577569830684407.pdf
Posted on Nov 04, 2009
Grinding noise in mowing deck when engaged
the bearings in one of the blade houseing r going out
Jul 01, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Tip
Warship: Flight Deck Jam
That's a cool game! Every equipment in the game is located on a block of space and can only move horizontally OR vertically
Read more: http://iphoneapplicationlist.com/2010/07/16/warship-flight-deck-jam/#ixzz0xijAktvj
on Sep 06, 2010 | iPhone Apps
Blade cable
The brake cable is a common part. Not sure which model you have, but you may want to check this one out, it's part #105-1844
Mar 30, 2014 | Toro Garden
My fLIGHT DECK WILL NO LONGER READ WHAT RING GEAR i AM IN IT STAY ON THE SMALLEST ONE NO MATTER WHAT RING GEAR I SHIFT TO
all the contacts for the flight deck are right there in the brake handles.. take the flight deck controls loose and give everything a good cleaning and double check your cabling to the deck... You may just have dirty contacts or a broken wire... otherwise...things may be wearing out in the shifters..
Aug 15, 2010 | Cycling
Unable to find fsx in windows registery unable to complete flight deck5 setup
Have you searched the registry using CTRL + F and typing in FSX or Microsoft? This should find all entries. If not, then FSX is not installed properly and you need to uninstall FSX, reboot and re-install. Good luck with it.
Jan 31, 2010 | Abacus Flight Deck 5 Expansion Pack for...
Shimano 105 flight deck diagram?
Oct 04, 2009 | Shimano Cycling
Paint skin not showing up on Flight Deck 5 planes
Check that you are running FSX and add-ons in administrator mode. This sounds like a user rights issue.
Jun 14, 2009 | Abacus Flight Deck 5 Expansion Pack for...
Broken shimano 105 flight deck shifter
You may have broken your derailleur cable. Your cable securing bolt on your front derailleur might have worked loose just enough for the cable to get some slack in it so that your derailleur isn't moving. Try completely loosening the cable bolt at your front derailleur. Pull on the cable and click the control to downshift to the inside crank gear . That should remove all the slack from the cable. Worse case scenario is when you pull on the cable it will completely pull out and it has broken at the shifter. You will have to replace it with a new one. If it isn't broken and you can still shift with the cable make sure your limit screw is properly adjusted for the inside crank ring and then pull all the slack out of the cable with the shifter shifted to that gear. Tighten the bolt that holds the cable in place and try the shifter again. It should now shift normally. If it doesn't you will have to take the bike in to have the shifter repaired. These shifters are not easy to repair unless you have the tools, parts and experience. Hope this helps.
Jun 04, 2009 | Cycling
Abacus flight deck 4 no aircraft carrier
Select the Load button on the flight setup screen. You will see many different flights you can take.
Apr 27, 2009 | Abacus Flight Deck 4 for Windows
Cycling Logo
3,666 people viewed this question
Top Cycling Experts
Marvin
Marvin
rigger094
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
