Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Compressor on side by side refrigerator not starting / cooling
Replaced starter and run capacitor
working again but slight humming on start up again after a couple of days
is adding a hard start capacitor and relay an option?
  • 585 Answers
I would certainly suggest the hard start kit. Also make sure that voltage drop in the line feeding the unit is not an issue. Check the voltage in outlet as the unit starts. Use a fast responding analog meter as a digital will mask the dip.
Posted on Jul 12, 2009
Maytag refrigerator Model mff2557heb wont cool
The compressor in your refig is bad. whats happening is when you let the compressor cool down it will run for a while then it starts binding internally until it gets to the point of humming and clicking. only repair is replacing the compressor. sorry for the bad news...
Sep 30, 2012 | Maytag MFF2557HE Bottom Freezer French...
Fridge and freezer not cooling
When the refrigerator turns on, do you hear anything in the refrigerant lines? Does the compressor turn on? or does it just hum?
If the compressor is running, it lost refrigerant charge. They were not made to be serviced and lack service valves.
If there is just a loud hum, the compressor may be siezed, the start/run capacitor may have failed. or the magnetic starter failed.
A service call is a fair portion of a replacement not counting the parts.
Apr 30, 2012 | Maytag MSD2732GR Side by Side Refrigerator
We purchased our Samsung rf276 6 months ago, and suddenly yesterday it stopped cooling both on the freezer and refrig side. We pulled it from the wall to see if it was an air circulation problem, but still...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 08, 2011 | Microwave Ovens
I have a Maytag side by side refrigerator when it is very hot and humid days, it stops working. The relay makes the noise every few minutes.It tries to start but then stops. After 24 hours, it will start...
Hi, When changing the relay the capacitor should also be changed... also the motor could be getting hotter on hot days causing longer run times and then the overload kicks out....that should also be changed but some compressors have the overload internally and they cannot be changed... do not know if that is the case for you... anyway the bit of extra heat can easily be the difference between it working or not...try to get more air flow around the compressor by pulling the fridge out from the wall a bit on hot days.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
Kitchen Aid refrigerator, model KBFA25ERWH01 – French Door / Bottom Freezer. Not cooling both frig & free. Unplugged to the compressor cool down. Unplugged and removed the capacitor and relay (DID NOT...
If the refrigerator try's to start and then shuts down, something is going the burn up. If it doesn't run, call a repair service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Apr 01, 2017 | KitchenAid Refrigerators
Frigidaire PLHS268ZCB1 freezer not freezing, periodic humming sound, Cold air instead of warm coming from vent underneath
Periodic humming is the control relay closing to start the compressor, only the compressor is not able to start. There is a lot of (inrush) current during this event so, after a few seconds, an overload cuts the power to the compressor and the humming goes away. About 30-60 seconds later, the relay tries again, the compressor hums but doesn't start, overload cuts power, rinse and repeat. If you touch the compressor during this cycling, it should be very hot. It's possible that the starter relay is bad. If you look at the compressor, there is a black box that plugs into the compressor on one end and has conductors connected to the other end. This is the relay / overload and can easily be replaced. There's also a capacitor plugged into that relay/overload. Be sure to discharge it or it can give you a shock. The capacitor on your model is a running cap, not a starting cap. Unfortunately, the most likely cause for the humming is your compressor starting to fail. This model is known for an unusually high compressor failure rate. You can replace the relay / overload with a "hard start" relay that is compatible with the compressor. This "should" extend the useful life of the compressor a bit but it will still eventually fail. The compressor may also be permanently damaged by the cycling so even the hard start may not solve your problem. It's a cheap part, however, and worth a try. Is it worth replacing a compressor? It's a sealed system and needs a professional with the right tools to perform the work. Usually it's between $400-$700. A comparable but brand new fridge is ~$1000. You'll have to weigh the cost. It's very likely that a $500 repair will get you several more years out of your existing fridge. Some would argue that for a few hundred extra dollars, however, it's worth the money to get a new one that's more efficient and under warranty.
Feb 20, 2009 | Frigidaire PLHS269ZC Side by Side...
Frige not cooling com not kicking on
Sounds like the compressor has gone out. Unless you can find a slightly more powerful starter capacitor that will be compatable. But then again, how long will that last you? My thought is, either have the compressor replaced or buy a new refrigerator. I am sorry for the bad news.
Mar 17, 2008 | Refrigerators
Refrigerator humming noise and loss of coolness in freezer.
the relay overload on the compressor is bad. its a very common problem. replace the relay overload and it will start back up again. ( relay overload is what your calling the starter)
Nov 27, 2007 | Refrigerators
Whirl pool side by side refrigerator problem
It looks like the Capacitor Start Relay is failing.  It is located either on the starter Relay or mounted on the side of the compressor compartment.  It sould have two wires on it, one orange and the other probably white.
Oct 22, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerator not cooling.
compressor has failed. not a diy job
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
156 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
