Question about Kenmore 659 Electric Dryer
Dryer (kenmore ultra care) is making a noise...
When i start my dryer, there seems to be something inside causing it to make a loud noise. I need to know how i could take care of this myself by taking the back cover off somehow to actually see what the problem is. I attempted to take the back off to no avail. Could you please send me a link to a schematic or a d/l of an owner's manual?
  • 248 Answers
Re: dryer (kenmore ultra care) is making a noise...
Remove 2 screws at filter area. Pull top forward and pull up. Remove 2 screws holding front on. Remove drum and check 2 drum rollers to see if they spin freely. If not, replace them. Also check idler pulley.
Posted on Nov 15, 2007
0 characters
3 Points
My kenmore ultra fabric care dryer won't start when I hold the start button down. It only makes a clicking noise.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Nov 21, 2010 | Kenmore 62602 Electric Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Loud Grinding noise in Dryer
I know this prob is old, but I had the very same prob with my dryer (very loud squeaking noise). The prob was that there was a screw stuck between the rotating part and the stationary part. Meaning - look inside the dryer (main area - where the clothes go) and rotate it by hand. You may hear and see something causing the friction. Gerard
Dec 29, 2008 | GE DSXH47EGWW Electric Dryer
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Dec 14, 2008 | Kenmore Dryers
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 659 Electric Dryer Logo
73 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
