Question about GE JVM1330BW/WW Microwave Oven
I need mounting instructions for the GE JVM1330. I have the brakets and the screws, but don't know where to drill the holes for mounting.
  • GE Master
  • 9,156 Answers
The installation instructions for this older model are no longer available for free download on the GE site, so you would have to order them or call GE customer service.
GE Customer Service is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Jul 13, 2009
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
I have a GE spacemaker microwave oven, and was woundering if there are mounting brakets sold sepert.
Here's the part number: WB56X10524
Also you'll need the mounting hardware kit:
WB01X10132
Go to RepairClinic and enter these numbers in the search box. You'll see pictures and prices.
Oct 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for the spacemaker GE microwave oven model JVM164owj01
Here is the link to the installation manual. Cut and paste on the address bar of your browser. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF It is possible to do it by yourself, but its a royal pain in the a**, so have someone available to help you lift it into place and hold it while you get the screws into the cabinet above. You could use sheet rock anchors to put the mounting bracket on the back wall, but I would really suggest getting the mounting screw into wall studs instead, even if you have to drill a hole or two through the mounting bracket.
Apr 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Installation of undercabinet microwave
If the OTR is the same model, the mounts should be the same. As long as you use the same bolts/screws from the old one, or the same length new bolts/screws, it should be a fairly simple exchange.
Mar 24, 2017 | GE JVM1440 Microwave Oven
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
The bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How can I install this oven GH9115XE?
You may be looking for this flat head 1/4 x 28 threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded holes in the top of the microwave:
GE # WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites)
or a set of three
GE # WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites)
Jan 21, 2008 | Whirlpool GH9115XE 850 Watts Convection /...
Microwave Ovens Logo
668 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
