Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Not even loading screen
Hi
My sagem str 6400t/6700t makes a whirring sound as if it is loading when youturn it on but nothing loads.Just get a black screen it worked fine 2 days ago now nothing. Tried to return it to shop but they wont take it without a receipt and it was a present from a relative.
The time on the box flashes but nothing else. Really annoyed.I've checked all the leads are connected correctly. It isn't even a year old and have only used it once, as I couldn't use it at my previous address due to reception and only moved into my new house on friday.
Anyone any ideas?
  • jessica_p989 Jul 12, 2009
    yes it does have a built in hard drive
    Has a standby button but I have switched it completely off, unplugged it.Moved it to another room and still nothing.It has a built in Hard drive
  • 44 Answers
Does the digitalbox has an inbuilt harddrive?? /David
Posted on Jul 12, 2009
  • 1 more comment
  • David Jul 12, 2009
    If you hear a whirring/buzzing sound, I believe it has something to do with the hard drive. Does the digitalbox has a function to turn it off or does it have a "RESET-BUTTON"? //David
    Okay, if you've connect the digital box to a SCART input, check that there are no AV4S, it should only be AV4 when you select the scart input on the TV. Othervise you're watching the SUPER-VHS input. Remember only AV4. no S after the combination.
  • David Feb 02, 2010
    Did it solved your problem?
I've a similar problem. It froze during a recording last night. Wouldn't switch on properly or off. I ended up disconnecting it. Reconnected hoping it would reset but it just whirrs loudly then displays 'init' on the box and a blank screen on the tv. Can't find a reset button anywhere on the unit.
Posted on Mar 31, 2010
My Samsung smart tv wont allow my Sagem DTR 6400T/6700T to operate/initialise when connected with HDMI cable. No scart on tv.
if the resolution of the sagem is too low it will not work or reset your sagem or switch the picture mode from scart to hdmi
Mar 27, 2018 | Samsung Televison & Video
Handset broken on model nosdtr 6400t/6700t
I have lost my hand set for the DTR 6400T/6700T
Where can I get a replacement?
Jan 04, 2011 | Sagem PVR 6280 Freeview DTV Receiver /...
Trying to find Channel 5
Maybe your area doesn't recieve that channel. every area has diffrent channels. But usally Channel 5 works in all areas maybe the signal prob.
Sep 08, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem dtr 6400t makes a whirring sound when you turn it on as if it is loading but nothing else happens. No screen is loaded so cant access any menus or anything
My Sagem DVR 6200T/6400T developed this problem. Initially, over a few days when I tried switching on the box via the normal button on the remote, the display would we black (no readout) but the box still made a whirring noise as if it was working and it would take about upto 15 mins for the display to come on and then I could use the remote as normal. After doing this for a couple of days the display evenutally stopped appearing, so the box would keep on making a whirring sound as if its was trying to initialise but nothing would be displayed on the readout and nothing happens if you press the handset. I tried turning it off and on at the mains plug, plugging the connections in and out of the box and television and at one point gave the box a 'smack' out of frustration. Amazingly I momentarily got a flashing error message:- either pb03 or p603 which upon looking online (for ages) apparently means an initialising error which seemed to make sense. NOTE- I do not recommend other people try 'beating up' their box. Anyway, this error never reappeared after turning the box off and on at the mains plug. After further research someone on this fixya site said try changing the Sagem adapor cable. I found an old external hard drive and the adaptor cable, which has the same input and output information as written on the Sagem AC/DC adaptor cable fitted and my sagem box now works fine again. And to think I was on the verge of paying out over £139 for a new box and amazingly all that was wrong with the old box was the cable! Points to note about using a different cable:- make sure the part that plugs into your box is the same size. Another adaptor I had rooted out from an external cd drive worked but it kept on switching the box off because the connection into the box (round plug) was slightly too small. The input should be 100-240V-50/60Hz and the output +12V=2.0A. Apologies for writing so much but because I no nothing about electrics I am trying to explain what I mean in laymens terms. I also suggest if you are in doubt, take your old cable into an electrical store like Maplins and get the advice you need about a new cable that is the same input and output as your sagem adaptor cable so that you do not plug in an AC/DC adaptor that could do further damage. AC/DC adaptors do not cost much and you may find that an universal adaptor set correctly may work.
I would like to thank the person who posted the solution because it worked for me and has saved me a lot of money.
Jul 12, 2009 | Televison & Video
ACER APSIRE BLACK SCREENING
are you using vista and installed any software newly?
if you installed new software in vista platform then problem occurs...
Jun 06, 2009 | Acer Aspire 5610-4648 Notebook
I would like a Sagem DTR 6400T/6700T software upgrade
Pop open remote case you will need knife or thin steel ruler to do this.
Clean the board contacts and the conductive pads with switch cleaner or isopropyl alcolhol cleaner and you will find it will work fine.
Jun 05, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
871 people viewed this question
Top Sagem Televison & Video Experts
Steve Allison
Steve Allison
ka4iup
ka4iup
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
