Question about Refrigerators
Our LG GR359SQ Fridge Freezer, the fridge has stopped cooling. Everything else seems to still work, freezer, lights etc. But the fridge is warm. Any thoughts?
    Sergeant:
    Champion:
  • 235 Answers
Make sure the the evaporator fan is running and circulation is getting to the fridge side. Remove anything that could be blocking the vent that brings in the air from the freezer to the fridge. Make sure that no frost is building up in the back of the freezer. If there is frost, then the timer can be going bad.
Posted on Jul 12, 2009
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
My freezer and refrigerator are working intermitently. Everything in freezer defrosts and fridge gets warm seems to be becoming more and more frequent.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Kenmore Top Freezer Refrigerator
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Fridge not cooling, freezer is ok.
Its usually a bulb of heat sensitive Gas then a long thin pipe that eventually connects to thermostate switch, bypass this switch to seee if that could be the faulty part. Good Luck , the Yeti
May 20, 2009 | Refrigerators
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Refrigerators Logo
351 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
