Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Water comes from under drawers on fridge side, leaks onto floor
This is a slow but persistent leak. Have turned off water for a week while awayl, but leak continued. I have ice maker and water dispenser, but that is on the freezer side of the unit. The water is coming from the fridge side.
    Sergeant:
    Champion:
  • 235 Answers
If leak continued then you must have a faulty cut off valve. Check and tighten valve. Also, check the hose that runs underneath the fridge for cuts or holes.
Posted on Jul 12, 2009
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
Rf266. Water collects under the bottom drawer of the refrigerator and results in leakage underneath onto the floor
Can you click HERE and read and or watch the video's so you can get an idea of what needs to be done behind the rear panel of the freezer to unblock the condensate drain Leaking Refrigerators.
Thanks, John Tripp Appliance 911
What is the model number?
May 01, 2014 | Refrigerators
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
We have a slow water leak in our fridge. The water pools under the bottom 2 produce drawers.
On most newer fridges, there is a very shallow 'V' shaped collection channel at the back of the fridge just above the bottom drawers, this is for condensate collection. In the middle of this channel there should be a hole, this quite often gets clogged, and over flows, hence the water at the bottom of the produce drawers, clear the hole and it should cure your leak, worth checking every couple of months.
Mar 22, 2011 | Samsung RM255LASH Side by Side...
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Jun 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
381 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
