SOURCE: hotpoint Aquarius WF740
Hello again update on error f05 was a sock blockage in the black rubber tubing that connects from bottom of drum to the pump it was a easy fix just plastic clips holding it on make sure you turn off electric first lol !!!! all working fine now.
thanks daddonk
SOURCE: Hotpoint WF740 Aquarius Plus Drum Seized.
hi the code will flash that because of the drum being seized in my opinion the bearings have seized to replace them you will need to remove the front of the machine disconnect all the wires from the drum not the machine there are two plastic pegs holding the suspension legs to the drum which you will need to remove. push the pins in at the backof the pegs and pull out the pegs,sorry you will need too remove the two concrete blocks top/bottom first, then remove the pegs lift out the drum remove the fixings around the drum with a t-30/t-40 bit,then split the drum now comes the tricky bit - AT THE BACK OF THE DRUM IS A 13MM BOLT UNDO THIS ONE TAKE OFF THE FLY WHEEL AND THEN REPLACE THE BOLT HIT THIS BOLT AS HARD AND AS CLEANLY AS YOU CAN WITH A LARGE HAMMER SO THE STAINLESS STEEL DRUM COMES OUT THEN YOU NEED TO GET THE OLD BEARINGS OUT THESE CAN BE A PIG SOMETIMES SO DONT GIVE UP THEN REPLACE WITH NEW ONE'S PUT BACK TOGETHER IN REVERSE ORDER.hope this helps if you can think you can do it it's not as bad as it looks ,good luck
SOURCE: filter
most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
SOURCE: My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Testimonial: "Ok thankyou...do i need to get an engineerto look at the machine?..Or is this a simple problem that I would be able to fix myself!? Thanks again!"
SOURCE: hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Testimonial: "Thanks for your help. In the end it was the front balance weight that had been gradually coming looser and looser and needed fixing pack into place."
