Question about Canon Pixma MP500 All-In-One InkJet Printer
The printer keeps on jamming the paper, but it still prints. do it need to be cleaned out if so how do you do that.
  • joyce8913 Jul 12, 2009
    maybe you did't understand me, but it does it one after the other, it con't to jam. I can't print anything on flat sheet of paper.
    the paper brings it in, then then it jams, right then and there
  • 44 Answers
If the paper stuck, you must open the printer and try to get the paper out, happens often with our fax. Good Luck
Posted on Jul 12, 2009
  • 1 more comment
  • David Jul 12, 2009
    Did it solved your problem? //David
    Tell me more about the problem, what happens when you're trying to print?? //David
    I would guess that it has sonething to do with feeding mode, ink cartridges or actuators. Are you using the correct ink cartridges? Does some paper works better than others? //David
Why does Paper keeps getting jammed in my v515w printer? I cleaned the print head and still having this problem!
You need to clean the paper feed rollers not the print head, use household rubbing alcohol.
Oct 19, 2016 | Office Equipment & Supplies
Why does my hp laserjet 1020 keep printing 4 blanks after each printed sheet? HELP!
My solution already posted in FIXYA.. for the same complaint earlier.pl go through..
http://www.fixya.com/support/t10478324-printer_taking_two
You need to clean the paper pick up solenoid located at down right side ...gently remove & clean it as shown..best of luck..
Aug 20, 2014 | HP LaserJet 1020 Printer
My brother mfc 240 c is keep saying paper jam but we have move the cover and we do not see a paper jam how do we resolve this issue please help
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum. get more information to fix brother mfc printer paper jam problem .
Jan 24, 2011 | Brother Multi-Function Center MFC-240C...
My printer keeps jamming paper and wont print. The light that says check paper is flashing. It jams every time.
1. shuffle the paper before feeding in paper tray
2. clean the paper pickup rubber rollers visible inside the printer with mild detergent and water and wipe off with clean cloth
Aug 12, 2010 | HP Photosmart C6180 All-In-One InkJet...
Paper keeps jamming in printer.How do I fix this?
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 24, 2010 | Canon PIXMA iP1600 Printer
Paper is jamming during printing process. Gets half way round and jams. please suggest solutions
There are rollers that the paper has to go between to be pulled forwards. When the rollers get dirty with paper dust, paper starts jamming. So you need to clean the rollers with a moist (not wet) soft cloth, Keep rolling the rollers manually and keep cleaning them. Then allow a few minutes to dry them up. And no jam after that.
Dec 10, 2009 | Dell 1100 Laser Printer
The printer keeps jamming when i try to print. The light keeps flashing and it says jammed paper but there is none.
Open the printer casing and clean the paper sensor and the tray . After that clean the rod with iso-propyle or petrol and remove all the dust from the board also.Your printer needs dusting only.Let me know when problem gets rectified.
Jun 25, 2009 | HP Deskjet 3745 Inkjet Color Printer
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
Canon Pixma MP500 All-In-One InkJet Printer Logo
51 people viewed this question
old marine
old marine
