Question about Maxtor (A01E250) 250 GB Hard Drive
Blinking power button
I don't know if this is a problem - just seeking an explanation or a possible link to a manual for this drive.
0 characters
1 Points
My Lacie 300794U suddenly blinks with a blue light but does not link up. Replaced power cord but still does the same thing.
disk drive p/s are very touchy. find the exact specs for the input for that drive. power adapters are within a general range and tolerance. you cannot mix any computer 5 volt adaptor. I took mine to a computer store, a small family shop and tied a toshiba 5v adaptor. and worked perfect. from the picture it appears that you are using an a/c 110v to d/c 5v adaptor. it it wirks intermittently then you may have a break at the bend in the cord, if it flucuates the adaptor interfaces may have a bad connection inside the drive box. if your handy open the lid and make sure the 5v connecter has the +5 red and gnd black haven`t come loose..the sneaky way is to go to best buy and purchase the exact same model and try the power supply, if successful you recover all the data and return the new unit. but you still don`t have a drive, or keep the new one and format the old drive
throw out the old adaptor and now you have 2 drives with one plug in. you can use the older formatted one to store partition image, and the new one for eveyday.. remember voltage in electronics kills ie. 13-14v will burn the drive, current is ok 1-3 amps no problem because this is what the drive can draw as required..THIS IS ONLYFOR D/C never use a variable voltage adapter like from radio shack, somtimes you set at 12v d/c and my multimeter reads 14-15
which will set on fire most electronics, portable radio etc.
I don`t know if you a computer or electronics background so I tried to cover my bases, hope this helps
May 21, 2015 | LaCie 300794u Big Disk Extreme Usb...
Will not turn on. green light on power cord is blinking but the unit will not turn on (the disc do not spin). need to recover files on HDD
Is this a Laptop or Desktop?
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 11, 2012 | Seagate Barracuda 7200.7 Plus (ST3160023A)...
Please help, this beeping noise want stop and I hope I haven't lost all of my pictures, pleases help
The noise you can hear is not a good one, it is a seek error which means the drive is dead, there are companies who can recover the data but it is not cheap.
Mar 10, 2012 | Seagate Freeagent Goflex Staa500108 500 Gb...
My external 1tb drive is not seen by my mac. The white light is flashing continuously and I can hear repeated seeks. reconnecting power and usb have no effect.
Welcome to Fixya!
OK, i have read the initial question/statement, and by the sound of it, you might have a bigger problem than initially suggested.
Firstly we will need to ask you a couple of questions. This will enable you to either diagnose the problem yourself, or give me feedback on the questions.
Does the "Seeking" sound you refer to sound like a faint clicking noise?
Have you plugged the drive into a Windows operating system to see if it mounts itself?
Are you sure all the cables and adapters are in good order?
If the seeking sound is a clicking sound, you might want to have a look at the following link.
Click HERE to navigate to link.
Please do not hesitate to let me know if you have any questions.
Kind regards
Jul 12, 2011 | Western Digital Wd Elements Se 1tb...
Need to know howto download
go to
in the top right hand corner of the hompage you will see a sofware finder which has 4 tabs
select the free option
these have drop down lists which you can select
once you have selected something click on the download link
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device 3.1/2 inch floppy or a usb device
hope this helps
Feb 15, 2011 | Hitachi 500GB 7200RPM 16MB BUFFER SERIAL...
My book essential has worked for several months now til now.... the white light is just blinking and my computer doesntg seem to recognize it anymore what should i do?
From the user manual (click here) on page 4, the slow blinking means that the drive is in standby mode.
The user manual does not explain how to get the drive out of standby mode, but you may want to try the procedure for powering off the drive that is on page 34 that say to press the power button on the back of the unit and wait for the LEDs to turn off.
If the unit does not power-off on its own within a few minutes of pressing the power button, the next thing to do is the following:
Shut down your computer with the drive still connected and powered-up. Once the computer is completely powered-down (no lights on or noise coming from the computer, unplug the power cord of the external USB hard drive and wait a minute. After you've waited a minute with the external USB hard drive unplugged from power, plug the power cord back in to the external USB hard drive Make sure the USB cable from the drive to the computer is properly connected. Power-up your computer using the power button on the computer and let the computer boot as usual. Once the computer has booted, check whether the external USB hard drive is now available.
Happy New Year and Thanks for using FixYa
Dec 31, 2010 | Western Digital My Book Essential 1TB...
Why does my hard drive blink
The light blinks to show you that the hard drive disc is working. It should stop after a while, but if not then you need to run a virus scan through it to make sure there are no bugs in it.
Virus can cause it to keep seeking and making the light stay on.
Oct 14, 2010 | Western Digital My Book Home Edition 500...
What type of drive is st380011a is called
This drive is an Ultra ATA drive. It requires an IDE connection to the motherboard.
Here are the specs:
Barracuda 7200.7
FORMATTED CAPACITY (GB) __________________80
ACTUATOR TYPE ____________________________VOICE COIL
CYLINDERS __PHYSICAL______________________
HEADS ______PHYSICAL______________________2
DISCS (3.5 in) ___________________________1
MEDIA TYPE _______________________________THIN FILM
HEAD TYPE ________________________________GMR
RECORDING METHOD _________________________EPRML 16/17 ZBR
INTERNAL TRANSFER RATE (Mbytes/sec) ______up to 85.4
SUSTAINED TRANSFER RATE (MB/sec)__________up to 58
EXTERNAL TRANSFER RATE (Mbytes/sec) ______up to 100
PIO/DMA/UDMA MODE (max) __________________4/2/5
SPINDLE SPEED (RPM) ______________________7200
AVERAGE LATENCY (mSEC) ___________________4.16
BUFFER ___________________________________2MB
Read/Write Multiple, Read Look-Ahead,
INTERFACE ________________________________Ultra ATA/100
SECTORS PER DRIVE (LBA mode) _____________156,301,488
TPI (TRACKS PER INCH) ____________________94,600
BPI (KBITS PER INCH) _____________________up to 595,000
AVERAGE ACCESS (ms seek/read/write) ______/8.5/9.5
SINGLE TRACK SEEK (ms seek/read/write) ___/<1.0/<1.2
MAX FULL SEEK (ms seek/read/write) _______//
MTBF (power-on hours) Office _____________600,000
SHOCK (G's, 11ms/2ms):
operating (Read/Write) __________/63
abnormal ________________________
nonoperating ____________________/350
fluid bearing (typ/max-quiet/max-perf) _<2.2//3.5
POWER DISSIPATION (watts) ________________
ACTIVE _______________12.5
IDLE _________________7.5
STANDBY (typ/max) ____0.9/
Mar 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Maxtor 120GB Hard Drive
Is that external???
Mar 24, 2008 | Maxtor Hard Drive
My Computer doesn't recognize Ion 320 GB Harddrive
Well if its lighting up, then the drive is receiving power, or the enclosure atleast. Forget that case, extract the drive, and seek out something more reliable and more solid. Preferably an aluminum enclosure with no fan.
seek out Weibetech.
Oct 15, 2007 | IOGear ION (GHD335C160) 160 GB Hard Drive
Maxtor (A01E250) 250 GB Hard Drive Logo
18 people viewed this question
Top Maxtor Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Maxtor Hard Drive Expert? Answer questions, earn points and help others
