Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Noise too noisy
  • 1,673 Answers
When the motor fan or motor bearings go bad, the motor will run real loud and will have to be replaced. Part #2031214 and sells for around $55.
Posted on Jan 17, 2008
Just started use my dyson dc07 it is new but is very noisy after my dc04 broke down.
Your dc04 breaking down is unlikely to be causing the excessive noise of your new dc07 unless you've trying to vacuum up the dc04 with the dc07??
It may be that the operating noise of a dc04 is lower that that of a dc07 however if the noise is excessive then you should get it replaced by the vendor.
Nov 12, 2016 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My DC24 is very noisy. What can I do?
Hi Nena, it's Jack at Dyson.
If your DC24 is making an unusual noise in use, our experts would need to listen to this over the phone to diagnose the cause and resolve the issue. It could be something as simple as a part or seal which is slightly out of place.
When you have your machine easily to hand, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a repair or replacement part is needed, we can also confirm if this is covered under your Dyson guarantee.
We'll look forward to speaking with you.
Oct 18, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
It is very noisy. What can I do?
Remove the filter out of the ball soak in warm water and washing powder for 30 mins then take it out side and give it a few bangs no wall or something dirt will come out the do it all over then rinse out and let It dry out fully and then give it a go in vac
Noisy hoover
1 Check the impeller to make sure it is not missing part of a blade or has something jammed in it that could throw it off balance.
2 Check the bearings on the rotating brush, especially at the belt end.
3 Remove belt and turn on. If noise still persists, it likely would be the motor is shot.
Jun 21, 2014 | Bissell Lift-Off Floors and More Pet...
Motor making a noise. I have a Hoover Canister S3573-016
A motor noise indicate a loosen parts of the motor. The bushing, brushes also a lack of oil or grease will cause a noisy motor.
Check motor and apply oil or grease, inspect also the bushing, brushes.
Good luck.
Jun 25, 2011 | Hoover Vacuums
Excessive motor noise. vacuum works fine.
Are you looking to reduce the noise of the vacuum? It is unlikely that you can do anything to reduce the noise of it. Vacuums tend to be very noisy so the best solution is to buy a quieter vacuum. This vacuum seems to be a popular choice for a quiet solution:
However, this vacuum is considerably more costly than the vacuum you own. A cheaper alternative would be this:
Both of these vacuums have high reviews and have been commended for their noise reduction.
Jun 17, 2011 | Bissell 3920 Bagless Upright Vacuum
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem.
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
I have a Shark corless sweeper since Nov 2004 and it now makes a lot of grinding noise. How do I get rid of the noise, it works well but noisy....
if its that old the plastic gears and parts are probably wore out. Euro pro does not provide many parts other than belts. might be time to replace it
Mar 04, 2010 | Euro-Pro Cordless Bagless Upright Sweeper...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Hoover very noisy after new belt installed.
what is the belt # you have installed (generic)? Yes, there are problems with using generic belts on Hoover Vacuums. If you have noise I would suspect the roller, and replace it. the cost is about $25 and is something that you can install. The newer type are mande of wood and are very quiet.
Nov 23, 2008 | Hoover U5753-900 WindTunnel Bagless...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
257 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
