Question about Sony VAIO VGN-NR120E/S Notebook
Screen shus off intermittently. Looks like
Screen shuts off intermittently. Looks like backlight goes dim. Sytem stays on, but very dificult to see
Screen sometimes lights up but mostly stays dim
You have a bad connection on the LCD ribbon, or a cracked LCD ribbon, or the Inverter is intermittently faulting, the backlight/circuit is faulting. It is hardly ever the switch....but it is under the end of the screen look for a tiny black stick.
Mar 02, 2010 | Acer 15.6'' Aspire AS5335-2238 Laptop PC...
Picture goes dark on different sections of screen intermitently then its ok for a while
Intermittent backlight lamps or backlight inverters.
If this model has an auto-dimming feature, try disabling that feature.
Oct 20, 2009 | Samsung LA46A550 46 in. HD-Ready LCD TV
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
Can i shut off the back light and or dim the
To change the backlight setting:
1.Press Menu/Ok >Settings >Display >Light Control > Backlight Control.
2.Select how long the backlight should stay on.(If you
choose Flip Open ,the backlight stays on as long as the
phone is open.)
3.Press Menu/Ok .
Thank you for using Fixya
Oct 08, 2009 | Motorola Mobility ic502 Cellular Phone
My screens works for about 10 or 15 minutes and then goes out...
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 03, 2009 | HP Pavilion dv2715nr Notebook
Intermittent video problem on acer extenza 5620.sometimes video display backlight will work sometimes it fails.
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 09, 2009 | Acer Aspire 5670 Notebook
Dark screen ,fn does not work
I would suggest connecting the laptop to an external monitor, just to make sure that it is all running correctly.
If you can see a very dim image on the screen then the backlight is out. This can be a light problem or the inverter that powers the backlight could be bad. The inverter is not real dificult to change and also is not very expensive. If it is the backlight tho, it is easier to just change out the entire screen.
Hope this helps
May 02, 2009 | Dell Inspiron 6000 Notebook
Acer screen looks dark?
  • Picture flickering with dim display.
Apr 23, 2009 | Acer Aspire 5315 Notebook
The display has dimmed, and looks washed out (faded)
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 05, 2009 | Toshiba Satellite 4010CDS Notebook
Backlight problem
if this is a new laptop, then I am guessing you are using it on battery, and you may have some power save setting turned on that is dimming the screen...
Take a look at your power settings under control panel...
M
Jan 01, 2008 | IBM ThinkPad T43 Notebook
Sony VAIO VGN-NR120E/S Notebook Logo
88 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
