Question about Motorola Mobility Moto Q
When calling voicemail, keypad won't acknowledge my password.
When I call to get my voicemail, I type the password in and the phone doesn't send the tones. I have tried typing # after the numbers, I have tried restarting the phone, I have even tried hitting the green (send) button after entering the numbers. It seems as if the keypad won't register the numbers. Also doesn't work when you get an automated answering machine and you have to choose a number to go to a topic. Help?
  • trishpa Jul 12, 2009
    Nevermind, I finally found the setting. It was under settings>phone information>DTMF. I set it for short and it worked.
When I check voice mails asking for password . I have forgotten password how do i reset please
Depending on if you use the Instant voicemail app or call into the direct line their are different reset procedures. Additionally it will depend on the specific carrier you use. I will include some common carriers so you can use which one is applicable.
Verizon
Press *611 then press SEND (airtime is free). Alternatively, call (800) 922-0204 (toll free) from any phone to reach the automated customer service menu. Listen to the instructions then when prompted, press 4. Listen to the instructions then when prompted say "Reset voicemail password".
AT&T
Call the AT&T automated system from your mobile device. Press "1" to confirm your wireless phone number. Press "3" to select Reset Your Voicemail Password. You will receive a temporary password via free text message.
Sprint
To reset your voicemail passcode:
Sign in to My Sprint with your username and password.
Click the My preferences tab.
Under Things I can manage online, click Change voicemail passcode. The Reset Voicemail Passcode window will open.
Dec 08, 2015 | Cell Phones
Cell Phone not activating
What is the maker and model of your phone?
Apr 16, 2008 | Cell Phones
Tip
Apple iPhone Voicemail Button Setup/Configuration
Apple iPhone Voicemail Setup/Configuration
Apple iPhone Voicemail occaionally doesn't set itself up properly and has to be configured manually.
  1. Press the phone button on your iPhone. (Green one, bottom left)
  2. Press the keypad tab.
  3. Type the following: *5005*86*yourvoicemailnumber#
  4. Press the call button and wait a few seconds.
  5. Press the voicemail button, and it will now call your voicemail.
UK Voicemail Numbers
O2 - +447802090100
Vodafone - +447785016005
Orange - +447973100973
Three - +447782333123
T-Mobile -+4406477897123456 (77897123456 - being your mobile number without the first 0)
on Dec 23, 2009 | Cell Phones
I am unable to get voicemail messages
Hi I may be wrong or not have all the facts, But, At first glance, voicemail is not an App or service that is associated with the iPhone 4 itself. How would you "edit" voicemail?? This service would be with your mobile service provider, therefore you should be able to call from any phone and check your voice mail. Here in Australia I delete Telstra voicemail by hitting 5 after the message is played back. Hope this helps solve your problem.
Jun 13, 2014 | Apple iPhone4 4G iPhone 4
I bought an iphone 4G and I am having trouble changing up my voicemail. It is showing an error that it can't
This is going to depend on what carrier you have, if youre going through a carrier that supports visual voicemail (where its downloaded automatically to your device, not where you have to call in) then you may need to setup your voicemail again. If youve forgotten your password you can call your carrier and hVe them reset it for you. They will either give you a temp password or just remove the password. You now have to reestablish a password and then put it in your phone. To call voicemail either press and hold the number "1" on your keypad under "phone" or simply dial your number and hit call. Once in your voicemail listen to the options, and choose administrative, or setup(these may vary by carrier) then "change your password". Once youve done that, hangup and then choose voicemail under "phone", it should prompt you for your password, just enter the one you just created and the rest should take care of itself. You can also call your carrier and get their assistance if that doesn't work, just call from a different phone so they will be on the line while you work it out. Good Luck!
Apr 12, 2014 | Apple iPhone4 4G iPhone 4
How do you extend ring time on a mobile phone
you cant they are pre programmed to run long enough for the caller to hear 4-6 rings before going to voicemail
Dec 28, 2011 | Samsung Cell Phones
I forgot my password to my cellphone could you please hel me to change and the #pwd# how do you use that becaus i couldnt type the letters pwd plzzzz help
dial #793# and press send.
Then wait a few seconds and the call will reset your voicemail password. The voicemail password will then be the last 4 digits of your phone number. Be sure to change it once you've logged back into your voicemail.
Nov 28, 2009 | Samsung Highlight Cell Phone
Samsung J700 I don't want voicemail
You can type ##002# into your keypad and press send. This will cancel all diverts.
Or
You can try calling 1210 and disable it that way.
Dialing 1211 will reactivate it.
Aug 31, 2009 | Samsung J700 Cellular Phone
Cannot access voicemail on Motorola Razr
If your wife never reset the codes when she used the phone, the "unlock" 4 digit PIN code is usually 1234, or sometimes the service provider resets it to the last 4 digits of your cell phone's number before sending it to you.
The SECURITY code is a 6 digit code which is set to "000000" when the phone is first sent to you and since your wife never used it that should still be it. I'd try entering 000000 for the "invalid security code" message you are getting and see if that does it. Some service providers may reset that security code before sending the phone to you too, so if any of those codes don't work you'll have to call your cell phone service provider to find out the codes. This info about all the codes was in my Razr V3 manual. Hope it helps.  If that does work for you and you can get into voicemail, then to reset the codes to your own personal ones go to ....Settings > Security > New Passwords and reset them.
If you get to the voicemail message screen and the message  stored there, (it's probably a message from the service provider) you have to call the voicemail number to retrieve the message, I just  press the keypad "dot" on the top right side under where it will say "call " and it dials & brings me to my voicemail.  The voicemail number should be stored in the phone, but because it was never set up you may have to call the provider to do so, I can't remember if it was already in there or not when I first set my phone up. Anyways......Good Luck & Happy New Year ; )
Dec 28, 2008 | Motorola Mobility RAZR V3
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
180 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
