Question about HP DeskJet 970cse InkJet Printer
Hp 970Cse not printing correct colors
My black gray scale is not correct and Cyan and blue not quite there. My computer says that I have 30% color ink remaining and 70% black.
Generally print quality is faint or pink
    Problem Solver:
  • 3 Answers
Get a new color cartridge or make color adjustments in whatever program you are using to get the printer all fired up. Scotto
Posted on Jan 11, 2008
I have a mac. how do i set up so i can start printing
Go to Canon website put in your printer model number an get the drivers an software for mac! hope this helps !
Sep 26, 2016 | Canon 3811B007AA model imagePROGRAF...
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
I cannot get my printer to print in only black and white. I have put new ink cartridges in, both color and black. I have selected "print in gray scale only" in the print options. But anything I...
Please take out the new cartridges and re-position them correctly i.e. color cartridge on the left and black cartridge on the right seating. Check that you hear a click sound when the cartridge is placed in the seating. Print a test page. Then switch off the printer for some time. Re start the printer and now carry out the gray scale printing.
Jul 19, 2011 | HP PSC 1210 All-In-One InkJet Printer
Is there any way to disable the color cartridge in my HP 930c? I want to print only in black.
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print. Most HP printers need at both cartridges in the printer for it to print.
Jan 18, 2011 | HP DeskJet 930c InkJet Printer
I never use any colour other than black yet I have to purcgase cyan, magneta, and yellow when my black cartridge is empty. Is it possible to overcome this problem, ? My printer isa DCP135C
You don't have to replace the coloured cartridges if you only use black. But if you print something that is not pure black then it will use the other colors. For expample, if you print on a gray scale, since this is a color printer it will use the colored cartridges to get the gray color. The colored printer will only use the black ink for pure black colours. If you just use black to print, why not use an inkjet printer that just prints black or uses black cartridge. It is available in the market.
Nov 08, 2009 | Brother DCP 115C All-In-One InkJet Printer
I just bought a new printer today its a lenmark Z2300m Color Printer i only have color ink for it do i need black ink for it because everytime i try to print it comes out greenish
Sep 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I HAVE A HP PRINTER "PHOTOSMART C5580" HOW DO I GET TO CHANGE THE DEFAULT INK. I VERY SELDOM PRINT IN COLOR, AND WOULD LIKE TO BE ABLE TO ALWAYS PRINT IN BLACK ONLY, EXCEPT WHEN I NEED TO GET COLOR AND TO...
To replace the ink cartridges
1. Make sure the HP All-in-One is turned on.
2. Open the ink cartridge door by lifting from the front center of the device, until the door locks into place.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch.
If you are replacing the black ink cartridge, lift the latch on the far left.
If you are replacing one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot.
Make sure that you insert the ink cartridge into the slot that has the same shaped icon and color as the one you are installing.
6. Press down on the gray latch until it clicks into place.
7. Repeat steps 2 through 5 for each ink cartridge you are replacing.
8. Close the ink cartridge door.
re Printing in black only - you can do this by selection this option from your application and choosing the print properties of the printer and setting to Black / Greyscale printing only.
Sep 20, 2009 | HP Office Equipment & Supplies
Can you force a printer to print in grayscale?
Yes, you can bypass the color printing. The software you are using for printing can help you change from colour to gray scale or adjust it in the printer properties.
May 10, 2009 | Brother MFC 420CN All-In-One InkJet...
Printing error message: cartridge problem.tri-color.I wasn't even
hi,
its becoz even if ur print contains only black text in it, while printer printing in black it needs a cyan or yellow ink to give very clear print out. work around for this issue, go to the printer icon and right click and go printing preferances and change the option to print only in blak or print only in gray scale. it should resolve ur issue............
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP DeskJet 970cse InkJet Printer Logo
194 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
