Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer just started squeaking loudly when agitating/spinning..faster it turns, faster it squeaks
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore stackable wash/dryer Dryer squeaks so loud. How do I stop the squeak.
You probably have a bearing in one of the rollers that spin when the dryer is turning. You'll have to take the front panel off and remove the dryer tub by taking the belt off. You'll then see two doughnut shaped wheels attached to the back panel. Check and see if one or both are loose on the shaft that holds them. If they are replace them. Lubercating is not an option. If they seem ok, check the wheel that the belt loops through and make sure it spins without wobbling. One of the three things is causing the squeak.
May 18, 2014 | Dryers
I have a kenmore stacked washer/dryer that squeaks in the spin cycle. What could it be??
i had that problem too. i noticed that is was not flat on the ground. You can also try putting oil on it.
Dec 09, 2012 | Kenmore 98702 Stacked Washer/Dryer
MY KENMORE STACKABLE WASHER HAS STOP SPINNING AND SQUEAKED BEFORE OPEN THE FRONT AND SEE METAL SHREADS
Sounds like you might have a bad coupler. Most of these washers are built by whirlpool and use the "direct drive" system so there is no belt. instead a coupler transfers power from the motor to the transmission. see if the machine agitates, if it doesn't, you have a bad coupler. This is relatively easy fix, but does have some complicated parts to it... If you want to try to fix it yourself, let me know and I will post detailed repair instructions.
Dec 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.84042500 stackable gas dryer. Started
It sounds as if the bearings in the dryer have gone bad. The same thing happened to my dryer.
Oct 22, 2009 | Kenmore Dryers
Kenmore top-loading washing machine squeaks
Hi
Thanks for using FixYa. Please check if there are any sucked small clothes, safety pin, lint or debris in the water pump. If the pump is fine then the squeaking sound may be due to gear dogs in the agitator or bad gear case. The washer will spin and agitate at the same time. If the washer is still under warranty then do not try to open, repair or replace any part to void the warranty.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 13, 2009 | Kenmore 22422 Top Load Washer
GE Washer Model WJRR4170E4WW squeaks while agitating
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
For more on do-it-yourself appliance repair help visit http://www.appliance-repair-it.com/index.html
Sep 11, 2009 | GE WBSR3140DW Top Load Washer
Squeaks really loud while agitating. Drains great, and works well other wise. Could the belt be going bad?
Could either be the drivebelt slipping or, if an older machine could be the main bearing getting dry.
May 20, 2009 | Washing Machines
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
Squeaking Washer
did you remove the shipping pins pins when you installed it
Jan 04, 2008 | Kenmore 22422 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
142 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
