Question about Digi-Tech Digitech Vocalist Live 4 Harmonizer
Rp2000, mdsper error
I have an rp2000, everytime i power up a message appears ''mdsper'' and it does not function ,i have tried to reset to factory presets but does not work ,is the solution to pay for repair
  • Anonymous Mar 14, 2014
    always have to set back to factory settings,now works intermitint
  • 192 Answers
If you have ever tried to research this error message and found that there is no real answer to this, it is because "mdsper" is a general error message that can be the result of a few things. It seems to be a senseless thing to do until you realize that if you were Digitech, this would be a boon to your service department when these things go out of warranty.
Most commonly, it can show up if the internal battery needs to be replaced. As you know there is an internal battery in order to store patches in memory. Well, these things tend have (in my experience) a life of between 3-8 years, but can last longer if the pedal isn't used much.
It could also be that a power surge could have knocked out the memory in the main chip, rendering the pedal completely useless.
Another common situation is that many people use a non-factory power supply (wall wart) and often it may have the correct voltage, but not the correct MaH. This mismatch can blow out the unit if too high, or cause the unit to malfunction, if too low.
You should also know that some people continue to do the factory reset procedure until it "takes". So sometimes continuing to try the reset procedure could lead to success. You may wish to try and reset it quite a few more times (maybe 20?), then, if you have the correct power supply and are sure that is not the problem, you may wish to switch the internal battery yourself. Apparently it is an easy replacement. The one thing i do not know is the battery information and where to obtain it aside from going directly to Digitech. I am confident you could find it cheaper through another source. Good luck. Hope this helps.
Posted on Jul 13, 2009
I have a Yamaha dtexpress. Very old, but works great. Except the snare sound. It is stuck on bongos. Is there a factory reset for the dtxpress?
1) Press the [UTIL] button.
2) Press the [PAGE DOWN] button until the 'Factory Set' screen appears. The message 'Factory Set' will begin flashing on the LCD.
3) Press the [SAVE/ENT] button. The LCD will display the message prompt, 'All data will be lost, Are You Sure?'.
4) Press the [SAVE/ENT] button again to complete the Factory Reset procedure.
Dec 31, 2017 | Yamaha Music
My korg N364 is out of tune. how do i fix it?
hello sir,
THIS IS SOFT RESET; FACTORY MUTE PARAMETERS WILL BE LOADED INTO ... ART, MULTIVERB LTX, No factory reset, remove battery for more than 5 hours. .... KORG, N364, HOLD ENTER AND 7, THEN POWER ON. KORG .... ROLAND, D-550, TUNE/FUNCTION AND MIDI DATA INIT: HOLD PATCH BANK 2,
thanks from: SHAAD GONDEKAR
Feb 21, 2017 | Korg Music
Won't reset to default. I get the AL message,,,then ot...then Gn.
Is this zoom G1N / G1XN? Try using the battery.
If the result is the same,there is a possibility of damage to the processor IC (ZFX3). But before be sure, try measuring the voltage as in the image below :
25895299-xykdzr1cdriwl1tmr4ngy0qt-3-3.jpg Gn error message usually appears because 1.8Volt voltage is not normal (or no voltage at all), and it is caused by damage ic ZFX3.
25895299-xykdzr1cdriwl1tmr4ngy0qt-3-1.jpg .
Oct 06, 2015 | Music
How to reset the Privia Px-110 back to factory setting
Try this
1. Turn off the digital piano
2. While holding down both the (TONE) and (FUNCTION) buttons, press the (POWER) button
Nov 17, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
When I turn on my Kurzweil PC2X, the LCD screen shows the message 'Scanner is dead!' followed by 'battery voltage low (0.0 volts).' The lights on the keyboard flash at me and the keyboard won't make any...
Try a factory reset.
Turn the unit on, and while the display says "Please Wait", press and release the Panic button. Press the right arrow button till the display says "Hard RESET". Press Enter, then the button under "Yes" in the display.
Sep 03, 2012 | Music
My rp90 reads out pd when i plug it in and is stuck in this pd mode and doesnt let me play anything how do i unstuck it from this pd mode
Try a factory reset. This is the procedure
1. Press and hold the Store button while powering up the RP90.
2. When the display prompts you with FR, release the Store button.
3. Press and hold the Store button for 3 seconds until RS appears in the display and release. The Factory Reset procedure takes approximately 10 seconds.
4. Once the factory reset has finished you will need to calibrate the Expression Pedal.
May 14, 2011 | Music
How to reset the pedal 25 ME? thank you.
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed.
Never turn off the power while factory reset is in progress.
Feb 15, 2011 | Boss ME25 Guitar MultiEffects Pedal with...
The Sustain pedal does not work.
When push comes to shove, a factory reset never hurts.
Assuming you'd like to proceed with a factory reset, follow these steps:
This procedure makes it possible to restore the S08 to the original factory-installed Internal Voices, Multis and System settings.
WARNING: The current settings for all Multis and User Voices will be deleted. If the current settings and data are not expendable, create a backup before executing the Factory Reset.
1) Press the [UTILITY] button.
2) Press the [JOB] button. The 'FactorySet' screen will be displayed.
3) Press the [ENTER] button. The 'Sure?' message prompt will appear.
4) Press the [INC/YES] button to execute the Factory Reset. The 'Completed!' message will be displayed to indicate the procedure has been successfully executed.
5) Press the [EXIT] button to return to the Utility Mode.
Oct 14, 2017 | Yamaha Full-Size Keyboard
Can a keyboard synthesizer play thru the DigiTech RP2000 to receive the effects by connecting to the midi in?
The short answer is NO. The MIDI connection does NOT carry audio, only commands. You must connect synth audio outputs to the inputs of the RP2000 and use the audio coming out of the RP2000 to have the effects.
Sep 24, 2009 | Digi-Tech Music
Getting an error message when starting the PSR 2100
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Sep 18, 2009 | Yamaha Music
Digi-Tech Digitech Vocalist Live 4 Harmonizer Logo
2,113 people viewed this question
Top Digi-Tech Music Experts
Ben Armstrong
Seanzilla
Are you a Digi-Tech Music Expert? Answer questions, earn points and help others
