Philips 17pf8946/37 has no video
Has no video only a white pinkish screen and sound
  • sashriver Mar 04, 2009
    Phillips 17PF8946/37, no video, no audio, no channel or menu will display on screen. Screen is black. Do not have original remote - using programmable remote.
Phillips LCD TV 17PF8946/37, has no picture at all on the screen, even menu and channel #s not showing in the screen. The screen just have blue color. Everything is working like switch & video. Please let me know what parts need to be replaced and where can I order the parts.
Posted on Nov 18, 2008
I have a Vizio SV470XVT1a. When I turn the tv on I may get a normal picture for a minute or two then the screen goes black or I will have a greenish or pinkish screen. I continue to have sound. Afte
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 10, 2017 | Vizio SV470XVT 47 in. LCD TV
What causes a black screen to have a pinkish tinge with visible lines on a cathode ray sony kd34xbr960n? And what might it cost to repair?
The video output section circuits has the fault. Might be a a video output transistor short. Type {Electro-help} in your search box and enter this site. It has all details.
Jun 08, 2012 | Sony FD Trinitron KD-34XBR960 34" TV
Hi, My monitor will once in awhile go from the warm white color to a slightly red or pinkish color. The monitor is about 5 years old and the model # is AL1913. Any thoughts? Thanks. Don
Red or pinkish cast on the whole screen? You may want to check the VGA connectors and pins at both ends. Also try it with anothe PC to make sure it is not video problem in the PC.
Basic LCD monitor and LCD TV troubleshooting guides:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed LCD monitors, LCD TV's pictures: http://s807.photobucket.com/albums/yy352/budm/
Dec 15, 2010 | Acer AL1913 19" LCD Monitor
The left side of the picture looks like it is in 3D. It has a pinkish color . the right side of the tv is fine. thank you for your time
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
Right now, my laptop screen is black. I can hit Fn
I'd guess that it's the CCFL (backlight bulb) going bad. What points me in this direction is that you mention that the backlight (when you're able to get it to turn on) isn't producing bright white light (and pink is one of the colors that normal fluorescent tubes produce when they're failing). You're in luck because CCFL backlighting isn't the most difficult thing in the world to replace (if you can handle delicate electronics) and you may just be able to hack together some LED backlighting for yourself while you're at it. There are a few reasons that LED backlighting is better than CCFL but the most important is that LEDs last pretty much forever.
There are a number of video tutorials on YouTube about replacing the backlight of an LCD display and a few of them detail the installation of bright-white LEDs in place of CCFL backlights. If soldering and math aren't your strong suits a drop-in replacement for the CCFL tubes should be fairly easy to find online...
Feb 06, 2010 | Acer Extensa 5420-5687 Notebook
The whites are not as white and there is starting to have a slight pinkish purpleish haze around the edges around the screen its not bad yet but I have tow and you can see that it is not as bright as the...
When an LCD starts getting pinkish to redish hues, the screen is starting to fail. You are in the biggining stages of losing the screen. There is no repair....only replacement.
Jan 16, 2010 | Apple Cinema Display 23" HD Monitor
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
View sonicvx2235wn
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
If you can hear audio then your problem should be in the inverter board.
It could have bad capacitors or possibly a burned out transistor.
There is a chance one of your bulbs is creating a problem, but you would usually see a flash of the screen if that were the case.
Even though you do have sound the power board could still be the culprit.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
Should the screen happen to light up all white, then your inverter is okay.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
ebaysbammbammfran
Oct 12, 2008 | ViewSonic VX2235wm LCD Monitor
My toshiba tn61x81 projection tv
have you tried the convergence option in the menu? i believe it is under "picture". this allows for nine different sections of the screen to be adjusted when projection images get out of whack.
Oct 20, 2007 | Toshiba TN61X81 61" Rear Projection...
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
