Error code E225
SOURCE: my printer canon imageclass MF4122
1- open the glass scaner
2- now clean the steel shift and the in the end shift you can see white plastic roller clean it by oil cleaner then but on it white greze let the greze be between the slote of the white roller tobe move good
3- another side of the shift you have amotor and tow plastice dishly clean it then but a greze on it noite not put mor grezs
4- now clean the glass scaner and teste your printer
if it's still in problem try whith this step
1- open glass of the scaner then you have white cable it's between the scaner lamp and logic change it and teste your brinter
if it's still in problem do it's end step and you will finish the problem
change the scaner lamp and not forget clean the stel shift in the begining when you clean the white roller and put on the steel shift a white greze
good luck
basher66 - Iraq- Ramadi -
SOURCE: system error e225
Canon imageCLASS MF4150 And ERROR E225 maybe others
Canon imageCLASS MF4150 Firmware Update V062 Windows 2000/XP/Vista/Windows 7(all x32/x64) from Canon Multifunction .
Hi there
This is because you need to update your Firmware,
So what I have don for you I have found the Update you need and I have put it on my website for you to download, this is a update for Vista / Win 7 / All 32Bit and 64 Bit.
Click Link = http://www.4all2sell.com/driver/Canon-MF4150_FirmwareUpdateTool_V062.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website is only there foe a limited time.
