Sir i've got problem with installation of the sim 2..my windows is vista home premium . is there any sim 2 installation that compatible with vista?
  • 198 Answers
This link tells you everything you need to know about running "The Sims 2" on your machine.
Hope that helped.
Posted on Jul 13, 2009
Did a clean install of my laptop. Windows does not acknowledge Windows Vista Home Premium
There will be a sticker on the laptop wi the product key. It will be in the format of xxxx-xxxx-xxxx-xxxx-xxxx Sometimes the sticker will be under the battery. If the sticker is not on the laptop it was either removed, or you need to make a complaint with Walmart.
Apr 17, 2013 | Dell Inspiron Computers & Internet
I'm using vista home premium os, however the problem I enccounter is once you install software which is compatible for windows NT, xp home and windows 2000, the software the one I installed is not properly...
Yes, if you use a Virtual Machine, you can install the version of windows you wish to work with, install the software, and it should work just fine.
You will however need a genuine copy of windows to install in the virtual machine.
You may be able to find an image of the OS you need, or a snapshot of an OS, to load into the VM, it all depends on the type of VM you are going to use
Sep 30, 2010 | Microsoft Windows Vista Home Premium with...
I had my comp. fixed and they put windows vista home premium on here and i can't play my old games that need xp what can i do
You can do 2 things:
1 - try to run them in XP mode  - right click on its icon, then Properties, then Compatibility, check 'Run this program in compatibility mode for' and select Windows XP in the drop down menu and finally at the bottom of the compatibility tab, check 'Run this program as administrator'.
2 - install http://www.microsoft.com/windows/virtual-pc/ , configure it and in it install XP and all the soft with problems, starting with the games.
Mar 07, 2010 | Microsoft Windows Vista Home Premium...
I have window Vista Home Premium\ Palm Tungsten E2
google your palm's model for vista and their should be a download for it if not, then it is not compatible for Vista
Feb 23, 2010 | Microsoft Windows Vista Home Premium...
Can i window vista install in 512mb ram?
Windows Vista recommended system requirementsWindows Vista Home Basic
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
Home Premium / Business / Ultimate
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
Source: http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx
Jul 11, 2009 | Microsoft Windows XP Professional
Sims?in vista?
sims2 has a problem with some cd burning software installed on your pc and a program called dvd ram. It is a good idea to update your directx to the newest out there. finally when you do get it installed you will need to go to ea website and dowload any patches this will make it compatible to vista
Mar 22, 2009 | Microsoft Windows Vista Home Premium with...
32 bit program to 64 bit opperating system
From the Autocad webiste:
System Requirements AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements Recommended configuration (excluding server components used with project management capabilities):
  • Intel® Pentium® 4 (3 GHz or higher); AMD Athlon™; multiple processors supported, dual-core supported
  • 32-bit only: Microsoft® Windows Vista® Ultimate/Business/Enterprise, Microsoft® Windows XP (SP2)
Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Here's how you should be able to run it in compatibility mode:
1. Right click on the Autocad Icon in your start menu
2. click on Properties
3. click on the Compatibility tab at the top
4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
Feb 07, 2009 | Microsoft Windows Vista Home Premium with...
Y my home premium vista is always not conpatible in software dat i install?
I will give you a few steps to take to make software more compatable with windows vista.
1. Make sure you have the most recent updates from windows update.
2. Make sure you have all the correct drivers. Check Device Manager to see if there are any errors.
3. Try right clicking on the software icon and choosing "run as administrator"
4. Right click on the software icon and choose proporties, then choose the compatability mode for the software if it does not say it it compatable on the back of the box and or software download.
Jul 21, 2008 | Microsoft Windows Vista Home Premium with...
Compatibility with Windows Vista
Sounds like you have a driver issue. Here is a link of all the sound cards that are supported by Vista: http://www.iexbeta.com/wiki/index.php/Windows_Vista_RC_1_Hardware_Compatibility_List#Sound_Cards I don't see your card in there, yet. Check with the manufacturer for updated drivers.
Apr 05, 2007 | Harman Kardon HK695 Computer Speakers
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
