Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Green power light
It will not stay on.  But after is sets for a time, it will come on.  this is speratic and we do not know when it will not come on.  some of the time it will shut down by itself.  The TV was purchased in 2000.
The green power light comes on for a few seconds then goes off .Its a 2000 model with low hours.
I checked the fuse. Its looked good and I giggled some things with the Tv unpluged.
  • 1,139 Answers
This might be due to a problem related to the SMPS (Switched Mode Power Supply) overcurrent / overvoltage dectection circuitry. When an overcurrent or overvoltage condition is noted the SMPS's shutdown circuit will turn the tv off. An over current condition can and most usually is caused by a component overdriving which causes an increase in current requirements for the power supply which in turn causes the shut down of the TV set. In an overvoltage condition a component may not function as well as it should causing a high resistance and this hig resistance causes the voltages level to go up causing the over voltage detector to activate shutting down the TV set.
The best this to do would be to take the set to a shop if you do not have a background in electronics.
I hope this helps,
Thank you,
Posted on Nov 15, 2007
What does service error 5C00 indicate?
Waste Ink Counter Reset due to residual ink in the ink docking station only resolution apart from replacing the printer.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
With the printer powered off (but still plunged in), hold down the "Resume Button" and press the "Power Button" and hold them both down.
While holding down the "Power Button", release the "Resume Button" and then press and release the "Resume Button" twice.
Now release the "Power Button".
The indicator light should blink in green and the printer will make some noises.
You know you are in service mode if the green light stops flashing and stays green.
Select one of the following service mode functions by pressing the "Resume Button" the specified number of times listed below.
Each time you press the "Resume Button" the light will change color to let you know the button was pressed.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
(4 times = Waste ink counter resetting)
5 times = Destination settings
6 times = Print head deep cleaning
Then press the "Power Button" one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
To Re-iterate :
You have to be pushing down on the resume button or the printer will just turn on when you press the power button.
Startin over.
Hold down the Resume Button then press the Power Button and hold them both down. The light between the buttons should come on green but the printer should not turn on. If the printer turns on at this point the printer does not recognize that the Resume Button is being pressed.
While still holding the Power Button down release the Resume Button and press it again twice. At this point the green light should change colors each time the Resume Button was pressed.
Then release the Power Button and you should be in service mode.
Once in service mode if you press the power button without first pressing the resume button the printer will turn off
Mar 31, 2016 | Miscellaneous
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
Jan 27, 2018 | LG Televison & Video
When I push the on button the green light comes on for second or two then goes out.(will not stay turned on long enough to even get a picture on the screen.Mitsibishi Model # WS-55315
This set has a self check feature--if set has been unplugged it clears the error buffer--plug in and try to turn on set.
When green light comes on and then goes off ON THE FRONT OF THE SET press and hold BOTH the menu and input(device) buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat the code for a total of five times.
Let me know what error code you find and I will explain it.
May 27, 2012 | Mitsubishi Televison & Video
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
Power will not stay on
Based on the model number WS65511, this set has a self check.
Turn on and when green power light goes out:
On the front of the set press and hold BOTH the MENU and INPUT buttons for at least 5 seconds and then release both buttons.
Power light will blink a two digit "error" code.
The most common is 2 blinks, a pause and 2 blinks. Set will repeat the error code at least 5 times.
Let me know what error code you find and I will tell you what it means, I hope you find it is 2,2 as that is the most easy to fix.
Jul 14, 2010 | Mitsubishi WS-65511 65" Rear Projection...
My ViewSonic monitor just blacks out for no reason
It could be a setting you could have done on the "Power Saving" settings under "Screen Saver" settings, if you have Windows XP. Like "Turn off monitor after" a certain time. Even if you don't have Windows, please check the Power Save settings.
Jan 29, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
The flashing amber light means the screen is in power save mode. Since you are not seeing a "No Video Signal" things are looking up.
You want to use the menu buttons on your screen to navigate through and locate the power save time out settings. Its best to set it for 'never'.
If that makes the change a fix, let me know, I'll guide you through the settings on your desktop display to control the display time out.
Jul 24, 2008 | Computers & Internet
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
