Question about HP Photosmart 435 Digital Camera
Kodak sd card needs formatting after tons of photos are on it?
I tried to upload my pics from the sd card on my laptop and now it needs formatting??? please help...i can't lose this photos. my camera even says it needs formatting.
    Genius:
  • 1,234 Answers
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
  • 864 Answers
#3
5
6
if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
4 Suggested Answers
SparkGap
  • 363 Answers
SOURCE: memory card problem
Assuming your camera acts like a removable drive when connected to the PC try the following.
  1. Right click the removable drive(your camera) in my computer and go properties>tools>error checking>tick both boxes>ok
  2. Wait till it finishes and check if you can now view the contents of the card. And copy to safe place straight away.
  3. Try http://www.officerecovery.com/freeundelete/ to recover any deleted files or fragments of damaged files.
  4. Let me know if any of this works.
Posted on Oct 22, 2007
  • 2976 Answers
SOURCE: Can't format 2 GB sd card for HP 735 camera
Make sure the SD card is unlocked. There's a tiny switch on the side. Put it into the camera. Under storage, when you select the card, also select format.
Posted on Mar 13, 2009
  • 43 Answers
SOURCE: sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Posted on Jan 29, 2010
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
Kodak C190 camera. I moved my pics from my SD card to my computer. Then tried to transfer them back..after many tries, they are back on my SD card. I can view them by putting the SD card in my laptop. When...
This should do it for you: Insert the SD card into your laptop or computer. In the SD card go to "New Folder" name that folder "DCIM" in the "DCIM" folder create a new folder. This one you will name "101KC190" (I'm pretty sure you have the Kodak Easyshare 190, correct?) Now, transfer all of your pictures into "101KC190." Insert the SD into your camera and it should work. email me if you need to kylejwoody@hotmail.com
Jul 22, 2011 | Kodak Easyshare C190 12MP Digital Camera...
Put in a 4gb SD card, camera says needs to format, I say ok, it say all pics will be lost, I say ok, and pick continue and then again it says needs to be formatted, and repeats this again and again
There are no 4GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 06, 2010 | Kodak EasyShare Z740 Digital Camera
Message "unrecognized file format"
Is the error message appearing on the caemra or the computer?
I will in both cases recommend to format the SD card and to update your firmware.
Format your SD card. NOTE this will delete all existing data on your SD card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
Scroll up or down to the Format option, then press the OK button
Instructions to uploading new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9637/9640&product=EKN032552
If successful please give me the feedback as a rating or recommendation. Thank You
Jan 25, 2010 | Kodak EasyShare C633 Digital Camera
My Kodak (SD Card 512MB) Memory Card Says Not Initialized ?
Pls. format the card.
Check if CD card lever is down/up
Test w. a different SD.
If your SD card is faulty there is a warranty on it.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jul 20, 2009 | Kodak Cameras
My Kodak C633 is not seeing/recognizing the SD card.
The reason this problem occurred is that you likely never formatted the card. The card will work fine in the beginning for the first few shots, but eventually will corrupt. But don't format that card just yet as it will erase the card.
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're very inexpensive these days:
http://www.amazon.com/s/qid=1246813724/ref=sr_st?keywords=sd+card+reader&rs=172282&page=1&bbn=172282&rh=n%3A172282%2Cn%3A%21493964%2Ck%3Asd+card+reader&sort=price
AFTER you've recovered the photos, format the card in your camera to prevent this from happening again (dig out that instruction manual to figure out how). Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
Jul 05, 2009 | Kodak EasyShare C633 Digital Camera
Uploading pics to mac from SD card in camera
Have you tried using an external card reader?
They look similar to this at Wal-Mart:
http://i.ehow.com/images/GlobalPhoto/Articles/4794433/120257_Full.jpg
I own a mac and always use an external usb card reader to download my pics and it works great. Also, I know that you need to get your pics off first, but you may need to reformat you card at some point so that it will read faster and work quicker in your camera.
For your software issue, have you tried download the software from kodak's website? The program shouldn't cause your apple to crash. I would try re-installing it from there website.
http://www.kodak.com/global/en/service/software/easyshare/en/dln_ekn026079.jhtml?pq-path=4509
May 25, 2009 | Kodak EasyShare C743 Digital Camera
Memory card says it needs to be formatted but i have pics on it and I need them..please help I will be waiting!
I had the same problem with my 4Gb card that has 750 photos on it. I tried doing different things, however, it did not work. At last I took the card out and blew on its chips, gave it a good shake and put it back. Then, the miracle happened. It could read all my photos. I guess there was some dust that had accumulated on the chips at the back of the card. Hope it can help you, too.
May 07, 2008 | Cameras
HP Photosmart 435 Digital Camera Logo
62 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
