Question about Jensen (654658) CD Player
My Jensen radio continuously seeks for channels,no reception.model#CD3010X
    Problem Solver:
  • 11 Answers
Check to make sure your radio wire is pluged in to the back of your sterio and if it is take it out and clean the metal on it so that it gets better connection
Posted on Jul 31, 2009
Have a new power acoustic csrvstereo DVD Bluetooth etc. Somebhowvi have it on the radio seek and it won't quit seeking I must have hit some thing to name but do this.
antenna loose perhaps try that it will keep seeking until there isa reception if no station come on that is because there is no good reception check the antenna cable. then it should stop seeking.
Oct 24, 2015 | Cars & Trucks
Jensen radio; model#cd3010x
capacitors may be blown
Jun 10, 2008 | Car Audio & Video
Cant get weather on my motorola MH370CR
Setting the Weather Channel
Your should radio receives weather frequencies if you are close enough to a reporting station:
1. After turning weather reception on, press . The current
Turning Weather Channel Reception On and Off
1. To turn weather reception on, press and hold + (plus) for three
seconds.
2. To turn off, press + or turn the radio off and then back on.
Your radio receives weather frequencies:
1. After turning weather reception on, press MENU . The current
channel flashes.
2. Press + or - to select the appropriate channel with good
reception in your area.
3. Press PTT to save the weather channel setting.
Here's a link to the MH user guide.
Best regards.
http://www.motorolasolutions.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MH230R-Two-Way-Radio/_Documents/MH230.pdf
Feb 02, 2014 | Motorola Radio Communications
No radio reception cracking sound
If it`s just a radio with no reception then check  that the aerial is fully plugged in correctly and making a decent connection
Sep 12, 2009 | Jensen CD400M CD Player
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
Jensen CD3010X Radio Problems
This happened to me too--with the same unit. I finally took it apart and found that the volume up button was shot. The tiny piece of metal that makes electronic contact had actually snapped in the middle causing contact to be made at random by bumps rattles or just about anything. Since the unit automatically comes on when the volume button is pressed, even turning it off was ineffective. So...I unsoldered one of the buttons that I never used much and soldered it where the broken volume button had been. I'm no expert, so I was rather surprised when the unit worked after i reattached it in my dash. Anyways, it was a cheap fix for a cheap--and poorly made deck. good luck
Mar 23, 2008 | Jensen CD4610 CD Player
VOX Transmit is "pulsing". Also, no wx channel reception
check if the mic is not dirty, there is nothing that you can do to fix this problem.
May 04, 2007 | Motorola Talkabout T6310 (14 Channels)...
Jensen (654658) CD Player Logo
187 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
