Question about Polaroid 15'' HDTV Monitor FLM-1511
Sound but no picture. menus work.
We get sound but no picture. We can see menu bars, etc.... but no picture comes via the cable. We swapped tv's and the cable connection works fine with another tv. We changed channels 3 and 4 and other variables with no luck. Is there something unusual that we might not have checked?
I had the same problem. In the menu, the image button was grey, and could not be hi-lighted, and the screen stayed blue. I was using the AC power cord. I plugged in the DC power cord instead, and it "woke" the unit up. I switched back to the AC power and it works fine. If you don't hve the DC cord that came with the TV, try andy 12 volt dc output cord with a positive tip.
Posted on Jul 30, 2009
How come my sound bar works when I do a self diagnostic sound test on my tv but there is no sound when i turn it to a channel
You could have set an incorrect sound mode to output via the optical cable. Check your TV to see what sound mode is being outputted via the cable. It could even be switched off!
Jun 18, 2016 | Audio Players & Recorders
My sound bar didn't come with the red/white aux cables. I had some at home. I plugged the red into the red, and white into the white, but, it's not working. And yes, the soundbar is on. My input lis
Think you can set sound bar to play via Bluetooth .go into the settings of the tv and look for Bluetooth.when the sound bar is on make it discoverable and the tv will pick it up.if you don't have Bluetooth then check to see if there is an option switch in settings to use external speakers.check cable and also check volume on sound bar is not muted.also see if you can link the tv to sound bar via optical link cable as this is much better than RCA red/ white audios which tend to fail as people pull on the cable rather than the plugs when removing them from equipment.
Dec 12, 2014 | RCA RTS735E Home Theater Sound Bar
Bush 4.1 sound bar cuts out, connected via optical sound cuts out it is intermittent, happens on tv, dvd/blue ray and media player setting. Any ideas how to stop this happening. Have tried rca cables etc
I get a similar issue from my Bush sound bar. The sound drops out when the tv programme/movie etc has a period of silence in the audio track or just very low background music (no speech). As soon as someone begins to speak it starts up, but usually it misses the first couple of words. Bar is connected directly to a Samsung tv via the optical cable. Any ideas?
Aug 12, 2013 | Audio Players & Recorders
Toshiba 36a43 i have picture but no sound. Volume control works but again still no sound.
Things to check:
In menu are speakers (audio area) switched on or off?
If you put sound all the way up and listen right at speaker what if anything do you hear?
If using a cable or sat box is sound turned down on it?
Is sound muted on set or the box (if used)
Do you have sound with a DVD etc hooked via the rear jacks?
A few sets have a slide switch on the rear= internal or external speakers--is it set to internal?
failing all of the above you have a audio circuit problem
Mar 26, 2012 | Toshiba 36A43 36" TV
My 22 lcd gives good picture but no sound.I've tried connecting an externel head phone but i don't hear any sound.
you're best bet is, depending on your TV's input/output, is to run your video components directly to TV via HDMI, component, etc., of course component requires additional sound cables, then run your sound out from TV via, best, digital optical, to reciever. You use the TV's menu to choose what you watch and, only have the one audio out. Scan your recievers menu to make sure you've got the right channel to listen to.
Jun 28, 2011 | Audio Players & Recorders
No image, only sound when connecting marantz sr 7005 hdmi out to hdmi in on tv philips 47pfl9632d
Whatever video components you have, they should be, depending on inputs on TV, should be run to TV first. Recievers do have pass through ports but, are not the best way to achieve picture and sound. HDMI cables are great but you r reciever may not be able to transfer the video. What I suggest is taht you run your componenets, cable/sat box, DVD, etc. via HDMI, componenet, etc., to TV input, then, run audio out from TV, via(best) digital optical. You can use TV's menu to choose what you watch while, you only have the one input to reciever. Scan your recievers menu to make sure you have selected the proper mode(TV, Aux, Vid2, etc.).. If you run your video unit to TV with component cables, you will have to get your sound through separate cable(s). Component cables have graet video, but do not carry the sound.
Jun 14, 2011 | Marantz SR7005 Receiver
Sony 60 in LCD edge LED TV: Hooked up new TV to a cable box - have HD picture but no sound. TV speakers say on. Makes sound when TV channel is changed (static). But nothing when input cable (via HDMI) is...
Your cable box most likely has a setting for audio HDMI such that HDMI sound is turned ON etc. rather than standard audio. Also check the TV settings for HDMI audio being set to ON. This should be a simple fix. HDMI audio usually is just a user setting adjustment and nothing more. Somewhere in your on-screen menus you should find the place to adjust HDMI audio.
Aug 12, 2010 | Sony XBR60LX900 60 in LED TV
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
Playing the sound of tv through the sound bars speakers
Not sure for the playstation etc, but for the TV the manual says using the (not included) optical link between TV and the main unit.
Note that this is not mentionned in all language versions of the manual.
Apr 10, 2009 | Samsung HT-X810T Theater System
No sound and sound menu stays muted so cant adjust
Have you totally unplugged the TV?
If not do so for 10 minutes and see if it resets.
Try to find a remote that goes with TV>
Mastersage.
P.s. Make sure you do not have the saftey lock on. You can adjust the control;s from built in adjustments.
Mastersage!
Feb 14, 2009 | JVC AV-48P575 48" Rear Projection...
Polaroid 15'' HDTV Monitor FLM-1511 Logo
201 people viewed this question
Top Polaroid Computers & Internet Experts
micky dee
Tom Chichester
Steve P
Steve P
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
