Question about Hotpoint Aquarius WF210 Front Load Washer
Very noisy when spinning
My hotpoint aquarius wf210 is very noisy when spinning. everything else is perfect about it
    Genius:
  • 1,239 Answers
Hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Posted on Jul 12, 2009
How easy/hard is it to change the barrings? It has become very noisy during the spin cycle. Thanks
It is not a easy repair to carry out, as it entails removing the whole drum assy from the cabinet.
Furthermore, if it is a 1 piece tub, by that I mean if there are no screws holding the 2 halves of the tub together, then it is not possible to fit new bearings, as you have to change the whole tub assy.
Good luck!!!
Mar 08, 2010 | Hotpoint Aquarius WF210 Front Load Washer
The water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Mar 08, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Washing machine noisy when spinning
this is joyce
you have got bad barrons in drum, they need to be replaced they will cost about $80.00 to buy and about 1 hour to replace by techn. if you do it yourself you need to go to ge.com and put in your model # and download your document and that will show you how to get a breakdown of your machine, this should help
thanks
joyce
Feb 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Water stil appears in drum even when machine is turned off
It is possible that you have a bad water valve. Turn off the water when the machine not in use if the problem stops the water is probably coming in through a defective valve.
Hotpoint WF620 - flashing error F05
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
Dec 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
293 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
