Question about Canon DR-9080C Path-Through Scanner
My Canon Dr-9080C isnt pulling the paper into the scanner. The input try elevates, and then returns to it's original position, without the paper being pulled into the scanner, as if there wasn't any paper loaded in the tray
  • 490 Answers
The scanner is assuming there is no paper. Just under the rubber rollers, in the paper tray there is a paper sensor. Clean that area with a damp cloth. Keep some papers and try "count-only". It it works then sensor is okay, else, you need to check the sensor.
S. Mohan, India
Posted on Jul 12, 2009
Error no page in Feeder when there are pages in feeder
Need more information. Does the doc elevator lift the paper to the pick rollers? Check the plastic lever that is attached to the upper feeder cover. Make sure the upper cover is closed properly Verify that the dark colored sensor is clean in the feeding tray
May 05, 2014 | Canon DR-9080C Path-Through Scanner
The DR-9080c scanner will take a whole stack of papers (20 or so) and shove it thru the paper path, not just the top sheet. On old laser printers there was a paper pick that got slippery. Is there one in...
Ensure that the "BYPASS" button on the control panel is not illuminated. Make sure the "Standard Feeding " is selected in the driver. Try cleaning the lower separation roller. Make sure the separation roller is pressing up against the feed rollers. If the roller set is worn, order a replacement set of rollers (Google: Canon 9080 Exchange roller kit)
Apr 04, 2012 | Canon DR-9080C Path-Through Scanner
Dr-9080c tray lifts up and down
IT could be a problem with the paper sensor. Please clean the sensor in the paper tray, it looks like a 'black dot' .
S. Mohan, Chennai, India
Nov 07, 2011 | Canon DR-9080C Path-Through Scanner
Paper tray at front of scanner will not lift. Scanner has been reset multiple times and computer rebooted as well. Error msg= unknown error canon DR-6080/7880/9080C driver versioin 1.3.10502.17001 (-4523)
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
Jun 30, 2010 | Canon DR-9080C Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C paper tray lift broken
Michael, U can buy 9080C service manual at tradebit.com 9080C has no belt for lifting the tray. It has arm and a few gears. Ensure that the plastic gears are not deformed. Good Luck. Which version of Capture perfect do you use?
S. Mohan
Jan 30, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C CaptrePerfect 3
Captureperfect 3 is not available on the Net. Only version 2.311 is available. (It may also be called upgrade) Download this and this can meet yr basic requiremnts. http://software.canon-europe.com/products/0010035.asp
The upgrades wont work without ver 3.0!
S. Mohan 94441 66426
Jun 30, 2008 | Canon DR-9080C Path-Through Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
237 people viewed this question
Clive
Clive
old marine
old marine
