intake drain light is on and dishwasher won't start. i cleaned out the dran but still doesn't operateintake drain light is on and dishwasher won't start. i cleaned out the dran but still doesn't operate
You can't post conmments that contain an email address.
you want the replacement to be white as well? Check out ApplianceArt.com, they have over 200 different panel options including stainless steel, black, and white.
No water intake, may be a defective intake hose valve. Miele calls it, the Waterproof System hose (WPS). However, first shut off your water valve to the dishwasher; disconnect the WPS; and inspect and clean the plastic filter. If the problem persists, then replace the WPS (~$170).
When this happens with my dishwasher it usually means that the drain is clogged with food/debris. To fix
1) remove bottom dish rack from machine
2) using a small cup, scoop out as much water as possible
3) remove inlet drain cover and unsnap the plastic insert and remove
4) rinse the plastic part and reinstall
5) start machine
6) if light still flashes, repeat steps 3 4 and 5 and restart
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks. Good Luck, Dan
Unfortunately you need a Service Rep out there to check the electronics - how old is the machine? - Warranty? the drain pump should be 220 or 120 depending on the model.
